Old 05-31-2012, 11:38 AM   #11
I'd like to see what you've done with your Roadtrip also. I just got the latest VW catalogue and see that the hose + adapter is around $90. So if there is a way some could use the external low pressure conn. underneath that'd be great.
Do you still get enough flow/pressure to get the grill to heat up okay?
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
myredracer is offline   Reply With Quote
Old 05-31-2012, 07:52 PM   #12
All right, here it is. With this setup, my grill works just as well as using the regulator that came with the grill and a portable bottle. I used the Camco kit #57635. I used this kit simply because the quick connect fit the female connection on the Lacrosse (Tracer is probably the same), and it was the only one I could find at a local store. The knob valve in the kit is not needed. The first pic is what my regulator looks like as supplied from Coleman. The second, you can see I removed the specialty nut from the regulator and using a nipple found at local hardware store, attached the quick connect from kit. This goes on one end of the hose from the kit, the other end of hose goes to trailer quick disconnect. Hopefully this helps.
ID:	14672   Click image for larger version
ID:	14673   Click image for larger version
ID:	14674   Click image for larger version
ID:	14675   Click image for larger version
2014 Ram 2500 Laramie CC 6.4l Hemi
2011 LaCrosse 296BHS
autorot8 is offline   Reply With Quote
Old 05-31-2012, 09:44 PM   #13
Does that fitting have a name? Where did you buy it?
[SIGPIC]2102 Tracer 2800rld, 2012 Chevrolet Silverado 2500HD, crew cab, 3.73 gears, 6 sp Transmission
qepv25a is offline   Reply With Quote
Old 05-31-2012, 09:57 PM   #14
Which fitting?
Old 05-31-2012, 10:33 PM   #15
TURBS's Avatar
i think the one in second pic
Old 05-31-2012, 10:43 PM   #16
If it is this, the male quick disconnect came in the kit. The brass specialized nut was from my regulator. I should have clarified that I had two Coleman regulators because my first RoadTrip grill was kindly liberated from my previous 5th wheel by some nice individuals that decided they needed it more than me, but were not smart enough to take the regulator, front legs, or grilling plates. So the specialized nut that screws onto the back of the grill can be simply unscrewed from the regulator assembly, and has female threads once unscrewed.
Old 05-31-2012, 11:22 PM   #17
BOBFIDY's Avatar
Originally Posted by qepv25a View Post
Hello...Does anyone know what type of gas line we need to purchase to use with the coleman roadtrip grill? We want to hook it up to the exterior gas line on our Primetime tracer 2800rld. We bought it from Amazon and 2 different gas lines but neither will do the trick. Hope to hear real soon. Thanks Bob
Bob...We also bought a Coleman grill and the first time I tried to use it I got fittings to connect to the gas line out of the regulator. THAY WAY DOES NOT WORK. The line is double regulated and does not put out enough gas. Went back to the friendly propane supplier and got a new set of fittings and got the grill hooked up between 1 of the gas bottles and the reglator and it works GREAT. I got the fitting aimed so that the gas bottle cover still works. Very well pleased how it all turned out.
2011 FORD F350 CREW CAB DUALLY DIESEL 4x2
2010 Salem LA 292FKDS
One of the Original 14 F.R.O.G.s
1st, 2nd, and 3rd INTERNATIONAL F.R.O.G. RALLY Branson. MO.
1st, 2nd, and 4th INTERNATIONAL RALLY Goshen, IN.
BOBFIDY is offline   Reply With Quote
Old 06-03-2012, 07:56 PM   #18
Walke's Avatar
Coleman Roadtrip direct connect
Thank you Autorot8 !! I was doing the same setup as yours. I had broken down a second regulator and when I went to the "propane shop" for a fitting the manager convinced me that Coleman uses a special high pressure regulator on these Roadtrip grills and even with this regulator removed it would not work well on the low pressure line from the trailer, so much for the "propane specialist". I ordered the fitting I need to adapt my 10 foot hose, thanks again Autorot8, it is guys like you that make this Forum a great community. I want to connect direct and not carry a 20 lb tank, great job Autorot8, the guy at the propane shop was very convincing, this now puts my project back on track. Great Grilling!!!
Ken & Judy
2012 Prime Time Lacrosse 301RLS
2014 Ford F-150 Lariat - Max. Tow - Ecoboost
Hensley Arrow Hitch
Average 50-60 nights/yr
Walke is offline   Reply With Quote
Old 06-03-2012, 08:33 PM   #19
Another thanks autorot8 for the info. + pics. I think I am going to look at doing this too.
On a related note regarding the Coleman grills, does anyone have a problem with pressure when coming directly off the tanks (with adapter)? I noticed on this past weekend, with our Roadtrip grill, when I turn on the 2nd burner and turn it right up, the flame on the 1st burner goes down quite a bit. Not really sure why this would happen? Just had the tanks filled so it's not because the tanks are low.
Langley, BC
Old 06-03-2012, 10:19 PM   #20
myredracer, On my previous trailer I used to connect directly to the 30# tank and did not have any problems with pressure. Unfortunately, I do not know what would cause this.
