Old 05-30-2012, 05:02 PM   #1
Thumbs down Coleman roadtrip grill gas line
Hello...Does anyone know what type of gas line we need to purchase to use with the coleman roadtrip grill? We want to hook it up to the exterior gas line on our Primetime tracer 2800rld. We bought it from Amazon and 2 different gas lines but neither will do the trick. Hope to hear real soon. Thanks Bob
[SIGPIC]2102 Tracer 2800rld, 2012 Chevrolet Silverado 2500HD, crew cab, 3.73 gears, 6 sp Transmission
qepv25a is offline   Reply With Quote
Old 05-30-2012, 05:06 PM   #2
TURBS's Avatar
need to see fitting on your grill .
Old 05-30-2012, 06:22 PM   #3
Need to know which one you bought:
Coleman RoadTrip Sport Grill
Coleman RoadTrip LXE Grill
Coleman Road Trip Classic Grill
Old 05-30-2012, 06:44 PM   #4
Walke's Avatar
Coleman Roadtrip Grill
You will not have much heat in your grill unless you connect to a high pressure tank, Walmart and Camping world have the adaptor hoses. These grills are made with Coleman fitting and regulator for a high pressure tank. Your external line on your trailer has been reduced to low pressure by the regulator at your tanks. If you "built" an adaptor hose to connect the Grill to the trailer the flame would be so small that a burger would cook in terms of hours. Been there, done that, now connected to a 20 lb tank.
Ken & Judy
2012 Prime Time Lacrosse 301RLS
2014 Ford F-150 Lariat - Max. Tow - Ecoboost
Hensley Arrow Hitch
Average 50-60 nights/yr
Walke is offline   Reply With Quote
Old 05-30-2012, 06:52 PM   #5
It is the roadtrip lxe grill.
Old 05-30-2012, 06:57 PM   #6
TURBS's Avatar
as walke stated the external gas line is low pressure .
coleman grill requires high pressure .
Old 05-30-2012, 08:12 PM   #7
bikendan's Avatar
Yep! Ditto. won't work.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-30-2012, 08:35 PM   #8
We have a Coleman Road Trip grill as well, but as far as the gas line goes, it should't matter what brand you have. You must connect directly to the propane tank(s) in order to get high pressure gas. The Coleman has a regulator that connects to the rear of it. You can get the hose at most RV supply places. You'll also need an adapter for the line to be able to connect to the tanks. Available at the same fine RV stores. We bought both items at Camping World and you can see them on their website.
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
myredracer is offline   Reply With Quote
Old 05-31-2012, 09:09 AM   #9
I have a roadtrip grill and use the external gas line. The roadtrip has that long specialty nut that screws onto the back, that is also attached to the regulator. The regulator can be removed, then I used a small threaded nipple to attach to specialty nut and hose. When I get home I can take a picture of my setup and send to you. It works great.
2014 Ram 2500 Laramie CC 6.4l Hemi
2011 LaCrosse 296BHS
autorot8 is offline   Reply With Quote
Old 05-31-2012, 09:17 AM   #10
TURBS's Avatar
Id like to see it as well.
