Old 08-23-2012, 11:55 AM   #31
ironj's Avatar
Originally Posted by jjarrard View Post
I will try again today. I have never been able to get a signal to receiver 2. I don`t understand since I have a lock on tuner 1. I have been acquiring satelite 61.5. I can watch satelite on both sets, but only on the channel selected at tuner 1. I do have the receiver set to dual mode. When I run a TV 2 channel search, the signal comes up on a high channel. I believe it was 113 or so. I tried both air and cable modulator settings. It is not a huge deal, but I am so close. I like the portability of the single LNB Winegard HD-1, but may look for used Dish Network dual LNB dish and tripod in the future. The Tailgater and Winegard auto tuning dishes only lock on a single satelite at the time. I want ot reinstall the fireplace and move on to other things. We are leaving for GA Vets State Park at lake Blackshear next Wednesday morning! I appreciate your inputs. I must be missing something!
i was referring to the actual tv unit scannig for channels in antenna mode...but now that i see you have a single winegard lnb, that is more than likely your problem....single lnb will run one tuner.....should work, but you will only be able to use tuner one and watch same program on both tv..what you need is a dual lnb like a dish pro plus with the switch built in to stack both 110/119 sat feeds down one cable.....its been a lOOOOONg time since i messed with a wingard....lol..but if memory serves me right, the single lnb wingard cant handle more than one "tuner"....
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
