Satelite TV Connections
As you mentioned, the dish connects into the multi-connections centre with the water, etc. The receiver goes in the cupboard above the fireplace and the connection is in to the right of the fireplace, wires can be fed up through the wire hole in the shelf of the cupboard. I marked the connectors after testing to find out which one is "satelite" and which one is "cable". With some short jumper connectors you also can feed the output of the receiver back to the Bedroom and outside connectors. Very well done by PT, I did not have to do any internal wiring.
Ken & Judy
2012 Prime Time Lacrosse 301RLS
2014 Ford F-150 Lariat - Max. Tow - Ecoboost
Hensley Arrow Hitch
Average 50-60 nights/yr
