Old 04-15-2015, 08:30 PM   #11
Crockett's Avatar
had a late thought...sort of after the fact. did you say coach was new? it would have been good to document install with pictures. sodium chromate begins to crystalize in the boiler chamber above 210 degrees. the small siphon tube there can get a layer in it(like hardening of the arteries) or block altogether. bottom line...damage may have been done to the core even with the fan. not trying to stir the pot...just stating known facts. should have a good rate of pull down and 60 delta T if operating properly.
Crockett is offline   Reply With Quote
Old 04-16-2015, 12:08 AM   #12
Same problem: here was my remedy on a 4 month old trailer.
I pulled my dometic out and lined the sides of the cabinets with styro board insulation from Home Depot. Also closed the dead space on both sides and top of refrigerator. Mine can be operated in zero inches of dead space. I closed up around the back edges and got a firm seal from the outside (did not close up coils or gas burner).
I then slid the fridge back in to the tighter space. I installed two medium 4 inch cooling fans on the back in place of the super loud single one that came fm factory. I also installed two 5 inch exhaust fans on the upper vent cover with very little space above for heat to get trapped. I removed the plywood baffle that was partially blocking the upper vent. Then ran wiring through the back next to the existing wiring and installed two switches on the front control panel to operate each fan bay.
Fans were high efficiency very low current 12 v fans. Cannot hear them running at all. I know I went overboard but that fridge cools quickly and stays an even 37 degrees. It was a night and day improvement and the exhaust fans activate for approx 2 minutes before shutting off. The other fans only come on when the ambient outside temps reach 95 degrees and shut down after 45 seconds. They will stay off for long periods of time. No more whining fan with continuous run time. No more battery drain, no more 50 degree fridge temps on hot days, no more hot interior cabinets around fridge.....it's refreshing!
2014 Windjammer 3025W Diamond 34.5 ft 8300 lbs.
2010 F150 SC XLT 4x4 5.4L, 3.55 gears 20" rims
12 k Equalizer WDH, Firestone Airbags, HD Bilsteins
TST 507RV TPMS
Zolin is offline   Reply With Quote
Old 04-16-2015, 01:01 AM   #13
Crockett's Avatar
due to potential flammability, i would advise against styrofoam anywhere in cabinet. fiberglass, though messy, is an excellent flame retardant. the ideal chimney piece is radiused flashing behind the condenser coil at the top curved to the top edge of upper vent. a couple fans, to aid natural convection, mounted in standard location is probably best. flashing best probably installed after unit is in unless you get elaborate. the core contains hydrogen gas. that and the presence of a flame means stay as flame retarded as possible since the core could always develop a leak.
Old 04-16-2015, 06:18 AM   #14
Witch Doctor's Avatar
Originally Posted by Jim Olson View Post
We have a new Primetime Crusader 295RST. The small cooling fan behind the refrig stays on all the time, no matter if on AC power or LP. We are dry camping for the next 18 days in Florida and seems I have to run our portable generator a couple times a day to keep battery charged. The unit is only two months old. Anyone else with a Crusader and the Norcold have the cooling fan run all the time?
Maybe I need to add a second battery.
Norcold uses a temp sensor located in the top fins. It will only come on when the fins get hot. I epoxied two fans together next to each other on top and used a double spade to hook the second fan up. Taking the baffle out will create better air flow. I also added a third fan in the bottom of the unit also hooked to the top sensor. When they come on it's really for a short time. Also using propane you will create more heat and the fans will come on more. A second battery would help, Not sure where I got this amp usage chart, but I attached it
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-16-2015, 07:41 AM   #15
Even approved foamboard which has a fire rating and foil backing used in home construction to meet fire code? I didn't state that part. The factory trim around the back edges of the fridge enclosure is uneven cut thin plywood with lots of gaps. Don't see how foam insulating board placed on the opposite side of that trim (toward the front of the fridge) in order to close the gaps could put me at higher risk of flames??? Even the sealed gap has pro grade foil tape all around the trim to eliminate exposure.. That being said, I agree the metal flashing at the top would be a more suitable ventilation solution. Sadly, the original install just had the hot air trapped above the top of the cabinet exposed directly to the underside of the roof of the slideout. All that hot air would move up, then backward and get trapped between the roof and the top of the fridge making it very hot. Now most of the dead space is eliminated, I agree about the fiberglass comment but the flame retardant rating was still within range of fiberglass insulation. I got my idea from an earlier posting which had pics, except that install was done with fiberglass insulation with backing around the edges. Thank you for your comment and concern sir.
TST 507RV TPMS
Old 04-16-2015, 07:54 AM   #16
With all the wood around?
Old 04-16-2015, 08:43 AM   #17
I'm guessing most Rockwood installs are done this way, at least on larger units where the fridge is actually in a slideout. Roof vent installs tend to vent much better. The thin uneven plywood encasement around the back edges leave a lot of gaps for LP and heat to enter around the edges.. I would not even consider placing anything beyond those edges in the coil/condenser/burner area of the back of fridge. The install specifications are explicit about this ventilation area needing to be completely open for air movement.
TST 507RV TPMS
Old 04-16-2015, 03:08 PM   #18
I would fill the seems with firer proof caulking same as they use for fire wall penetrations in construction. If you are having a problem with trapped heat at the top in a slide out I would build a scoop to direct it out of the dead area and out the vent. The fan is about 6" below the outlet and coil that would move your air out the vent. And your right units with refers in a slide do not cool as good as a straight vent. That's why extra fans help and the scoop.
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-16-2015, 03:13 PM   #19
Is Hydrogen gas the same as ammonia?
Is ammonia explosive?
Pure ammonia is difficult to ignite and has a very narrow range of flammability. Ammonia is flammable only at high concentrations and under extremely limited conditions. Ammonia vapor that contains oil or another flammable contaminant can increase the possibility of an explosion. However, ammonia will not sustain a flame on its own; ignition of ammonia vapor requires an uninterrupted external flame source.
Back
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-16-2015, 03:40 PM   #20
Crockett's Avatar
ammonia is boiled off of water. water vapor condenses in the top leaving pure ammonia. this is brought into contact with hydrogen gas which is reacts with the ammonia absorbing heat during the reaction. this compound later is brought into contact with water which pulls the ammonia off of the hydrogen and the process repeats...
fan
