Old 04-15-2015, 09:07 AM   #1
Cooling fan on Norcold refrig
We have a new Primetime Crusader 295RST. The small cooling fan behind the refrig stays on all the time, no matter if on AC power or LP. We are dry camping for the next 18 days in Florida and seems I have to run our portable generator a couple times a day to keep battery charged. The unit is only two months old. Anyone else with a Crusader and the Norcold have the cooling fan run all the time?
Maybe I need to add a second battery.
bluecolorkat is offline   Reply With Quote
Old 04-15-2015, 09:10 AM   #2
TURBS's Avatar
Fan may run 24/7 if the fridge is turned on.
Some units were thermostatically controlled I think.
You could locate the fan and install a switch.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-15-2015, 09:40 AM   #3
Crockett's Avatar
The first ones were. If they deleted a thermostat to save money i would not be surprised, seeing how dometic deleted the dehume switch. Be discreet about how you add a switch, i.e. Dont cut a wire just break it at a spade connector. Dont want to loose warranty over it. If your under 90 degrees, just disconnect. Pull the upper side vent and see how it was vented. Check the refer install specs, see if it was done to spec. Refer manufacturers are very specific here to get a good draft on the "chimney" as its known. The fan may be cheaper than good venting labor. Double side vents do work, they struggle in heat. In case Ive broken any forum rules, this message will self detruct in 10 seconds...
Crockett is offline   Reply With Quote
Old 04-15-2015, 09:42 AM   #4
TURBS's Avatar
Agree Crockett,
A second 12v battery or two 6 volts should be considered regardless with that many days dry camping.
That fan Altho a draw is not your only draw.
Your fridge requires 12v to run on propane.
Same goes for your hw heater it requires 12v to run on propane.
TURBS
Old 04-15-2015, 10:11 AM   #5
B and B's Avatar
I changed the one noisy Fan first week we owned the Fiver for 2 quiet fans with slightly more airflow and much quieter performance.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-15-2015, 11:42 AM   #6
mike.t's Avatar
Don't think the OP is concerned with noise B and B.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 04-15-2015, 12:01 PM   #7
frozen's Avatar
Was going to put a switch on my fan until I felt how much heat it was moving. I suspect that my ice cream would just be cream without it.
frozen is offline   Reply With Quote
Old 04-15-2015, 06:00 PM   #8
Cooling fan Norcold Refrig
Found out what was causing the cooling fan to run all the time. Found that the top baffle was bent down almost closing off upper exhaust vent. It appears that when factory installed refrig and pushed it back it bent this baffle downward almost closing off upper vent. The two cabinets on either side of refrig is very hot. The only way to fix it is to pull refrig and try to straighten baffle or replace.
This should have been caught before it left the factory. I'm dry camping the next 18 days so have to come up with a fix.
Old 04-15-2015, 06:39 PM   #9
Crockett's Avatar
you prolly just saved your cooling unit. might as well say the whole fridge. just remove baffle and operate with top vent door removed, weather permitting...you'll vent fine.
edit: with the cooler weather the top vent removal may not be necessary. can you extricate the baffle??...
Old 04-15-2015, 07:36 PM   #10
Closed off refrig vent
Was able to remove damaged aluminum baffle. Upper vent was pretty much blocked off. It could have been a fire hazard. Will fabricate a new baffle tomorrow so I can continue on this camping trip.
fan
