Old 09-02-2013, 10:48 AM   #1
Correct Tire Pressure
I have 235/80/16 on my 290 RLT. The tire and the trailer say max cold @ 80 psi. I just checked them and have 60 psi in each tire...the way it came from the dealer. I read several posts and am still not sure what is correct. Do I need to increase them to 80 psi or are they okay at 60 psi? I know the 80 is cold however with all of the tire horror stories I have read I don't want increase my chances for a blow out. Thanks.
Smokin is offline   Reply With Quote
Old 09-02-2013, 11:18 AM   #2
What I do and what I would do
I run mine at max cold. I suggest you do the same. Not enough air can cause a blow out on a bad bump or pothole & cause the tire to run hot. Trailer tires are bad enough without adding to the problem.
IMHO
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 09-02-2013, 11:39 AM   #3
Camper Less Camping
Cajun Po-Boy's Avatar
Inflate & run at max listed PSI
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 09-02-2013, 11:39 AM   #4
Yes, run them at what the trailer sticker says.
A friend of mine ran his at 45 for almost a year because that's what they came from the dealer with. Finally he noticed the sticker on the RV that said 60! He's very lucky he didn't have a blowout.
Old 09-02-2013, 03:35 PM   #5
It depends on some things.
If the tires are ST ( special trailer), then the maximum load is calculated for more deflection because that is allowed at lower speed ( 65m/h).
So try to determine the maximum speed of the tire. J stands for 100km/62m/h and Q stands for 160km/99m/h. If you now have a low speed tire with that more deflection allowed, substact 15% for STor J speedcode of the maximum load before filling in in my Traveltrailer-tire-pressure calculator.
You also need the AT-pressure/maxloadpressure/reference-pressure ( your 80 psi given on the tire.
And the GVWR ( gross vehicle weight rating) or real weight .
and ofcource the number of tires on the road when driving ( so not spare and nosewheel) .
Because most trailers have tires that can bare yust enaugh to carry the GAWR, the needed pressure is mostly that AT-pressure , but higher is allowed.
Even stiffer TRA system allows 10 psi extra above your 80 psi so 90 psi .
And because of the yust enaugh maximum load, in combination for the lower speed, that 10 psi extra is needed to keep the tires undamaged.
But give all the asked details, and I will give a full report.
jadatis is offline   Reply With Quote
Old 09-02-2013, 04:18 PM   #6
I think my head just exploded. I'm a little confused and I'm not sure I know all of the answers but they are ST tires. The GVW is approximately 11,500 pounds.
Old 09-02-2013, 04:25 PM   #7
Camper Less Camping
Run at max cold psi listed on tire...all good from there
Old 09-02-2013, 06:43 PM   #8
Nigels's Avatar
Run at max always, make sure you are at max when cold and all identical on the psi, first thing in the morning is a good time to check.
Check often even when hot just expect a higher reading than max and all tires should be the same, +-1 or 2 psi, this could because of uneven loading, camber on a road or most likely the sun on one side and not the other.
Don't trust your dealer! When we collected our RV we did the walk thru and "yes" they had checked the tires, 200 miles later 2 blow outs same side and the other side were at 37 psi should have been 50psi. I ended up replacing all 4 tires! I had to fit E rated its all they had in stock, 30000 miles later I don't regret the few $ extra, I have peace of mind even tho its overkill.
Nigel & Bev
Brit Driver & Canadian Naviguesser
We summer in Cowichan Valley BC Canada & winter in Monchique Portugal great camping in both!
2011 Rockwood Signature Ultra Lite 8280ws 2011 Dodge Ram 3500 4x4 Diesel 2000 Honda S2000
Nigels is offline   Reply With Quote
Old 09-02-2013, 07:00 PM   #9
Commercial Member
Info from a real tire engineer.
Shame on your dealer. You can point to the RV Certification label and ask the dealer why he thinks he knows more than the RV MFG or tire engineers.
Maybe the dealer also thinks its ok to run TV engine a qt or two low of oil.
Here is a post explaining why TT should run the inflation molded on the sidewall, which is also probably the inflation on the label.
ST tires are rated to carry more load because they are speed rated at 65 MAX which results in cooler running and their tread depth is less than LT tires which allows cooler running. Since heat is a major killer of tires lower heat helps tires live longer.
I have never seen an ST type tire with an SAE Speed symbol such as J, Q or R etc. so don't be confused by looking for something not on the tires.
We don't need to get into HD techno speak. Just realize that multi-axles place sideloads on the tires not seen by motorhomes, pickups or cars. Increased tire inflation lowers these loads that are trying to tear the belts and tread off the tire body.
.Write a blog on RV tire application RV Tire Safety. 48 years experience as tire design & forensic engineer. My RV Freelander 23QB on Chevy 4500 chassis. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Mar 20-22 Tucson AZ
Tireman9 is offline   Reply With Quote
Old 09-02-2013, 07:18 PM   #10
5verdriver's Avatar
Go by the tire stamp, not the sticker on the trailer. Same goes for the tow rig. I know people that go by the sticker on the door jamb on their truck, but what if the tires they're running are different from the factory ones?
2013 Palomino Sabre 36 QBOK-7
2012 Ford F-350 SRW 6.7 CrewCab ShortBed
PullRite SuperSlide 18k IS Rails
2006 HarleyDavidson RoadKing Classic
5verdriver is offline   Reply With Quote
Old 09-02-2013, 07:21 PM   #11
A question for you Tireman, that I've never had a clear answer to. Lets make this specific about Goodyear Marathons, and let us know if your answer is specific to those.
On mine, the Max Cold pressure is 80, with speed limited to 65. The Goodyear webpage says that you can increase pressure by 10 pounds to increase the Max Speed to 75. Does that mean that you can increase the pressure to 90, or is it that you can increase pressure above that needed when you are at lower loads, but NEVER over "Max Cold" of 80?
Thanks.
Old 09-03-2013, 11:41 AM   #12
Commercial Member
Thanks.
OK this gets a little technical.
First, if you have followed my posts here and in my blog I strongly suggest that tires on multi-axle trailers be inflated to the pressure molded on the tires. I suggest this so that you have a chance at improving tire durability.
I know the GY Tech Bulletin is not clear but having discussed this with GY they say you should not exceed the inflation molded on the tire sidewall.
I do understand the concept of changing speed rating with an inflation change. What is also true is that the +10 mph 65>75 is the maximum speed increase covered by Goodyear in their document.
My concern is that Goodyear fails to consider the special side loading seen on multi-axle trailers.
In my blog post on "What should Trailer owners do" I discuss some of the unique problem they face. The unique side loading causes what is known as "Inter-Ply Shear" between the belts and edge of the tread. This force is trying to tear the tire apart from the inside out. You can lower these high forces but not eliminate them by decreasing the tire load or lowering the "Sip Angle". You can lower the slip angle by increasing the inflation.
My concern is that ST type tires like the GY Marathon have higher load rating based on the assumption that you will go slower (less heat) and the tread depth is less (lower heat). BUT if you increase the speed you may be generating heat faster than it can be dissipated so you end up doing permanent irreparable structural damage to the tire.
This technical paper explains how increasing the tire pressure lowers the tire distortion when cornering. Lower distortion means lower inter-ply shear. Lower inter-ply shear means longer tire life. "Changing inflation pressure affects tire force and moment characteristics. This is because changes in inflation pressure alter the size, shape and contact pressure distribution in the footprint of the tire. In general, increasing inflation pressure will cause the size of the footprint to shrink, raise the contact pressure near the center of the footprint and allow less tire distortion"
So you have a choice.
You can increase the inflation above what is needed for the load (which I suggest)and get longer tire life at the same max speed
or
you might increase the inflation and run up to 75mph but have less tire durability. It is your choice but you can not expect the increase in inflation to give both longer life and higher speed capability and you cannot increase the inflation above that molded on the tire sidewall.
Old 09-03-2013, 11:49 AM   #13
Commercial Member
Sorry not quite correct.
For TT you give the correct info but for the wrong reason. For motorized vehicles your suggestion is most likely wrong.
Vehicles sold for highway use by law have a Certification label or "tire Placard" applied by the vehicle mfg. This provides the tire type, size, Load Range and inflation recommended by the vehicle mfg.
The tire company does not know the weight of the vehicle a tire may go on so can only provide information based on what inflation is needed to carry the max load.
Cars, pickups and motorhomes can adjust the tire inflation so that the tire can carry the actual load on the tires.
TT with multiple axles could do the same but if the TT has multiple axles there are special considerations which usually result in the inflation recommendation being the inflation molded on the tire (see my prior post)
If an owner changes tire size or load range it the vehicle owner's responsibility to know the actual tire loads and to establish the proper inflation based on actual loads.
Old 09-03-2013, 12:36 PM   #14
Denver, CO
garbonz's Avatar
Tireman9,
EXCELLENT information, and the first logical engineering based explanation that I have seen.
Anyone that has turned their rig into a tight spot on asphault and has watched the tires scrub around and try to tear themselves off the rim has a small sense of the "special" side loads that you are talking about. I have LR E tires on a trailer that could handle with LR C and I keep them at close to the Max pressure (75psi) figuring the increased pressure keeps the tire cooler, the side loads lower AND they will be replaced LONG before the center tread wears out anyway. Trailer sure does bounce alot tho, oh well ther are tradeoffs everywhere.
2017 Fuse 23T
Old 09-03-2013, 01:28 PM   #15
Commercial Member
Garbonz
Thanks. Sometimes I worry bout going too technical. I do plan on an expanded post or two on this topic on my blog. If you subscribe you will only get a notice when I make a new post. I usually do about 3 a month.
Roger
Old 09-03-2013, 01:40 PM   #16
Phat Phrog Stunt Crew
awwall's Avatar
Excellent information Tireman9!!!
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 09-03-2013, 03:57 PM   #17
Then also give the number of tires that ride on the road and the number of axles.
And from the tires the maximum load and that AT-pressure .
We now know they are ST tires wich may bare more because of the lower speed, wich heat up the tire less so at more deflection same heat-production as an LT tire for instance at that higher speed. Its not even to say that the heat does the damage . Shal play an important role in it all, but the repeated strain of 10 to 20 times deflecting and flexing back of every segment of the tire, could do the damage.
But if you have an LT tire the speedcode gets important, to know for wich speed they are calculated . But I did not knew that you had ST tires in my last post, so also wrote about the speedcode by a letter.
And ST tires sometimes even get damaged at the AT-pressure ,
Better is to give them the same deflection as an LT tire of same sises and AT-pressure, if that can be done by 10 psi higher pressure then AT-pressure.
For truck tires even 20 psi higher is allowed ( when is it called a truck tire?).
So what I am trying to make clear is , calculate it as it where an LT tire of same sises, and if then pressure is 10 psi above AT , you are save to laws of nature, and the TRA cant say you have used a to high pressure, because they allow it.
Old 09-03-2013, 04:57 PM   #18
Smokin
I have a 2012 290RLT with 235/80/16 tires and have always run them at 80 PSI with no problems in 6K miles. I have weighed my trailer at each wheel position while hooked to my TV. The actual weights are as follows RF 2,050 RR 1,850 LF 1,900 LR 2,800
2008 F-250 PSD 4X4 Pullrite SuperGlide 15K
2012 Crusader 290RLT Touring Edition
Cascade Bob is offline   Reply With Quote
Old 09-04-2013, 10:53 AM   #19
Commercial Member
Cascade Bob
Thanks for the info. One question. Are your tires ST or LT?
Hint: When writing a tire size it helps if the letters in front of the numbers are included. It also helps if you include the "Load Range" letter. C, D, E, F etc.
Old 09-04-2013, 11:19 AM   #20
Mister's Avatar
or
Great write-ups. Very informative. I run my trailer at tire max pressure which was 80psi on my old trailer and higher than the sticker pressure on the trailer. I will eventually be replacing my D classes on the new rig with E class radials for the slip angle reason you mentioned above. My trailer has a wider axel spacing than is typical and you can feel them flex and drag during sharp turns.
My trucks tire pressure I run at tire max (50 psi) when towing. The rest of the time I back it down to sticker pressure (35 psi) to protect suspension and steering components.
2008 F150 FX4 5.4L & 3.73s
2014 PTM Tracer 3200BHT
Yes...I've finally made it to Prime Time!
Mister is offline   Reply With Quote
pressure, tire
