Old 02-25-2014, 02:59 PM   #11
Somewhat right of center
Crabbyguy's Avatar
The quick connect coiled blue hose for the outside......I have no use for it plus I just about broke it trying to hook it up. I couldn't get it to click in no matter what I did. Even if I did I still need adapters to use it.?? I've used many quick connects but this one I took off this past fall and am going to replace it with the outside shower white hose and nozzle like I had on my TT. The outside quick connect for the propane I haven't used yet.
Crabbyguy is offline   Reply With Quote
Old 02-25-2014, 03:05 PM   #12
Todouble's Avatar
Crusader 260RLD Touring Edition
Originally Posted by donzie67 View Post
Not sure I understand. You have a cable and satellite connection in the docking station. I also forgot about the antenna on the roof. So all 3 let's call them supplies (cable satellite and antenna) feeds are different? Do the all connect to the outlets next to each tv?
When at a full hook up site you put the cable feed in to docking station "cable" outlet. Leave the wire at tv hooked up to cable outlet. But if you run a sat dish the you feed into "sat" connection in docking station and you have to swap outlets at your tv to sattelite one. As far as just using your antenna do knowing other than push the booster button next to the tv, raise your attenna, and you may have to switch your tv from cable to antenna input.
Todouble is offline   Reply With Quote
Old 02-26-2014, 02:30 PM   #13
donzie67's Avatar
Does anyone have a picture of the two TV connection plates? The one in the living area and the one on the ceiling in the bedroom. Not having my camper at home or even in my state yet is getting tougher to figure things out that I want to do it it one it is delivered. Thanks for all the help.
Prime Time 2014 Crusader 260RLD Touring Edition
2006 F-250 4x4 King Ranch FX4 6.0 Powerstroke Diesel
Don & Katrina + Copper the Beagle
Nights camped 2012 = 48, Nights camped 2013 = 46, Nights camped 2014 = 47, Nights camped 2015 = 49
donzie67 is offline   Reply With Quote
Old 03-10-2014, 09:17 AM   #14
donzie67's Avatar
Does anyone know if this rig is equipped with a water filter system?
Old 03-10-2014, 09:21 AM   #15
Todouble's Avatar
No on board water filter system. You would have to add your own or use an external inline style with your hose hookup
Old 03-10-2014, 09:22 AM   #16
donzie67's Avatar
Old 03-10-2014, 10:06 AM   #17
Crabbyguy's Avatar
The weather is breaking here so I'll be going out to the rig today to check a few things. I'll get some pics for you.
2014 Crusader 260RLD Champagne Touring Edition
2013 Silverado 2500 6.0 HD
Old 03-10-2014, 10:11 AM   #18
donzie67's Avatar
Thanks. We had snow again this morning. Too warm to stick but tired of it any way. Was finally able to get to my old one and start getting everything out of it. 99% done. Just the back cargo carrier with the generator, blue boy and storage box have to come off yet. A quick cleaning inside and then done.
Old 03-10-2014, 10:22 AM   #19
Crabbyguy's Avatar
I'm just south of you in Delaware and I'm about sick of snow (and I love snow) and this weather. I'd like to maybe use ours the end of this month but I'm afraid it'll sink in the mud if I try to pull it out....hell, I'll just get some plywood if need be. We're supposed to get temps in the 60's this week and that should be my chance to wash the outside and get it ready for the season. Dewinterizing will be done last.
Old 03-10-2014, 11:00 AM   #20
donzie67's Avatar
I have family down that way in Dover. Been there a few times in the past 30 years.
Another bad thing right now. The dealer wont let it leave the dealership not winterized. So I can not run water and test the plumbing out. They say they pressure test everything but that does not tell me if the pump is going to actually pump or just make the noise like it is. This is where you have to trust your dealer I guess.
crusader
