Crusader 270 RET Slide Out
After retracting our dinnet slide/refrig., when it gets all the way in, before it stops, it makes a loud clunking sound, then stops. When we go to extend it back out, all you hear is the gears clunking and nothing is moving. In order to get it to extend, I have to crawl under the unit, remove the access door, get out my rachet and get the slide to extend out about an inch, then it will fully extend. I have noticed that the Barrel Sleeve and nuts are both loose on the threaded rod, don't think that is right..What should I do now...something is not right...Everything worked fine the last time we used it, but with these parts being loose, I believe something has become out of adjustment!
LKicklight:
