Old 05-16-2012, 10:46 AM   #1
crusader 290 doesn't look level
We've had our crusader a few months now and I've noticed that the trailer always looks a little lower on the curb side than the street side. I measured from the bottom of the rear bumper to the ground on each side and found that the curb side is about 3/4" shorter. I then measured from the bottom of the front of the trailer and the curb side was 1 1/4" shorter. All of the tires are inflated the same. I did not measure from between the tires on each side. We've put a couple of thousand miles on the rig and there is no visible tire wear on the tires. Is this a problem and should I be concerned? The rig pulls great and the uneveness is not apparent in the camper when on a level pad.
Pete
pryner is offline   Reply With Quote
