Old 05-29-2015, 02:43 PM   #1
Crusader 290 RLT Wiring diagram
Looking for wiring diagram on rv receptacle to distribution panel in rv on a Crusader 290 RLT. I am trying to wire in a 50 amp progressive industries surge protector and the white wire seems to run to the battery box. All the wires are buried under the counter and I am having a hard time finding and wringing out the wires as they enter the RV Any help would be appreciated. Thanks
brireey is offline   Reply With Quote
Old 05-29-2015, 02:51 PM   #2
TURBS's Avatar
The wires you should need will be in a big heavy bundle such as your power cord.
It enters the back of your distribution center and goes to the main breaker.
Behind your distribution center if room allows is where you should put your surge.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 05-29-2015, 03:08 PM   #3
Thanks for responding Turbs
I have pulled the draw out to access the back of the main panel box, the area is tight but room for mounting the surge protector. I am having trouble finding the white wire, does that wire go to th converter? I just can't seem to see it. Also pulled out the main panel and still coul not locate it.
Old 05-29-2015, 03:10 PM   #4
TURBS's Avatar
The wires that go into the back of the panel to the breaker are not in a jacket ?
How many is there?
TURBS
2011 32bhok Sabre
Old 05-29-2015, 03:14 PM   #5
They are out of the jacket, I have a red, green, black and can not find the white
I should have a white being a 50 amp
Old 05-29-2015, 03:15 PM   #6
TURBS's Avatar
Odd, hopefully someone with a like model can help.
TURBS
2011 32bhok Sabre
Old 05-29-2015, 03:19 PM   #7
I did find a #6 white a going to the battery, not sure where it comes from as it is buried by heating ducts or is running in the underbelly which is enclosed, and I can't trace it.
Old 05-29-2015, 03:21 PM   #8
TURBS's Avatar
That wire will be 12v and obviously not what you need
TURBS
2011 32bhok Sabre
Old 05-29-2015, 03:22 PM   #9
I will take a harder look tomorrow. I am getting old and maybe I am looking right at it and can't see it
Old 05-30-2015, 05:46 PM   #10
I have the 325RES floor plan so not sure if identical to yours but I also installed the same protector. I unscrewed the 6 or so screws inside the basement and removed the wall to gain access for installation. I was able to see all the wiring and have plenty of room to work. Have you tried going in that way?
__________________________
2014 Crusader 324RES
2012 F250 4x4 6.7L
FarmerTex is offline   Reply With Quote
crusader, diagram, wiring
