Old 06-22-2014, 12:15 PM   #21
290RLT Frig
Hi Jim,
I have a 2013 290RLT and they may have made a change after the 2012.
My 1/8" piece of plywood is 24" by 42". The bottom is attached to the outside wall near the bottom vent with one screw. At the top they added a 1" piece of wood to the side wall and then attached the top of the 1/8" plywood to it. This moved the plywood 1" closer to the fins. It also brings the 1/8" plywood in flush against the fans. If this sounds right to you then it sounds like you did the right thing by moving it 1/2" closer to the fins. My photo tries to show what mine looks like after installing the new fans.
Dale
2013 Crusader 290RLT
2013 Silverado 2500HD 6.6L Diesel
Crusaderguy is offline   Reply With Quote
Old 06-24-2014, 08:49 PM   #22
J_KHawthorne's Avatar
Originally Posted by Crusaderguy View Post
Hi Jim,
Dale
Yep!
It looks a little different!
Jim & Kathy
2012 Crusader 290RLT TE, TrailAir flex pin: 2012 Toyota Tundra 5.7 SR5 Dbl cab 4X2 Tow, 4.30 gears, RideRite air, TRD cold-air induction & dual exhaust: Reese 16K Slider: TST tpms
Miles towed to date: 18,950 Nights camped 192
J_KHawthorne is offline   Reply With Quote
Old 06-26-2014, 05:08 PM   #23
LKicklight's Avatar
Fan Noise
Like hearing the fan run, lets me know that the darn thing is workinjg just fine...ours at the moment is not. For some reason the unit kicked off during the night, did not switch to gas and never came on..now we are 5K miles from home and no reepair facility within 200 miles, Talkeetna, AK.
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 06-26-2014, 06:41 PM   #24
Try bypassing the fan thermostat. Possible the tstat is broke. Its located in the upper vent attached to the fins.
volwing1 is offline   Reply With Quote
Old 06-28-2014, 04:37 PM   #25
Replaced the OE fan with two fans. Much better...faster cooling and virtually no noise! An unexpected situation was the two wires' insulation had become kind of brittle making it more difficult to splice to the the new ones.
Old 07-01-2014, 10:35 AM   #26
rracer5's Avatar
Sorry, Just caught this. Had the same experience on my Lacrosse once. Questions; 1 - Is there any power to the fridge? 2 - Were you stationary "off level" for any length of time (couple hours)?
#2 will cause #1. If so, the thermocouple may have tripped. It is located behind the "shield" just above the burner for the burner chimney. It IS resetable but should be replaced as once tripped, they become "weak" (told to me by the RV tech who replaced mine).
Hope this helps now or in the future.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
