Old 04-07-2013, 01:58 AM   #1
Crusader 290RLT Heating System Question
Does anyone know if the Crusader 290RLT heating system has a return air vent? The air conditioning system has 2 vents in the ceiling but I am unable to find any return vents for the heater. Was thinking I needed to clean a filter but can't find any to clean.
Thank you
Crusaderguy is offline   Reply With Quote
Old 04-07-2013, 06:25 AM   #2
Commercial Member
huntr70's Avatar
There are no filters in the heating system.
Look for a section of louvers in the cabinetry, that is the air return.
Sort of think that model has the furnace under the sink area somewhere....
Steve and Vicki
2 kids
2011 Dodge 3500 CTD Outdoorsman
(Tweaked!!)
2013 Columbus 320RS-ITS HERE!!
huntr70 is offline   Reply With Quote
Old 04-07-2013, 06:47 AM   #3
M109Rrider's Avatar
My heat return is under the stairs.
Jason and Billie
2018 F-250, 6.2L
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 04-07-2013, 11:48 AM   #4
Heater return vent
Thanks Wildcat....If the louvers on the side of the sink under-cabinet are the air return then the air is flowing back over all the cleaning materials we have stored under the sink. That doesn't sound too good. It sounds like there is no filter that needs to be removed and cleaned. From another post it appears that other Crusader models have a return under the stepup. Is the lack of a proper return and filter a deficiency with the 290RLT model?
Old 04-07-2013, 12:10 PM   #5
M109Rrider's Avatar
No filter on the 320 heating, only filters on the a/c. Past camper (Keystone) was the same way.
Jason and Billie
2018 F-250, 6.2L
Old 04-07-2013, 09:10 PM   #6
on_the_bayou
PrimeTime's Avatar
The air conditioner in some PTM models is designed to help circulate the air in your unit if desired. If you prefer to not have the additional circulation, you can change the fan settings on your thermostat to AUTO while in furnace mode. Consult your Thermostat User Manual for instructions
2012 Crusader 290RLT
2012 Silverado 2500 Duramax (175,000 mi)
Camping:
2012: 4564 mi 31 days - 2013: 6277 mi 38 days
2014: 5146 mi 38 days - 2015: 1200 mi 9 days
2016: 342 mi 2 days - 2017: 2734 mi 22 days
PrimeTime is offline   Reply With Quote
