Old 04-06-2018, 07:04 PM   #1
Red face crusader 294RLT axles weight rating
I was curious as to which axle the other people's crusader 294RLT have.
Mine has 6 lug 5200 lb axles.
that has me musing about this:
if I am correct that means the actual gross allowed weight that I can legally be is 10,400 lbs. my certificate of origin listed my shipping weight as 9,061 lbs.
which means my cargo allowance is 1340 lbs.
I have a 60 gallon fresh water tank when filled weighs 498 lbs.
I spend 1/2 my time boondocking which leaves me 842 lbs. for every thing else I wish to bring. ie. food, clothes, generator, chairs, bedding etc.
5th with slides 33 ft pin to back bumper
2015 Crusader 294RLT (Jul 2014)
2007 3/4 ton dodge 6.7 diesel
retired military
home is Fort Smith, Ar.
MEL T is offline   Reply With Quote
Old 04-06-2018, 08:14 PM   #2
rracer5's Avatar
15 - 20% (depending on how much & where you load it) is supported by the pin. So, according to PT's web site the 294RLT's GVW is 11,450. At 15% on the pin, that would make your axle weights 9,732 & at 20% the axle weights would be 9,160. So, you are well within your combined axles capacity of 10,400 lbs.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
axle, crusader, weight
