Old 08-11-2017, 07:58 PM   #1
Crusader 295 island sink drain slow
My 295 island sink does not drain can't see why. Only soapy water has been in the sink. The dealer states the sink has its own tank but I only have one grey tank valve. It appears like the system is just full. The drain worked fine when first using the sink. Of course the dealer wants it back to sheik for a pinched flex line or clogged vent. What am I missing?
RG03 is offline   Reply With Quote
Old 08-11-2017, 08:23 PM   #2
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
you should have a second grey valve just ahead of the forward tire, tucked up high near the frame.
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
Paulie1138 is online now   Reply With Quote
Old 08-11-2017, 09:08 PM   #3
Look up high near the frame on the right side of the waste pipe. That's where the second gray dump valve is on our 297RSK. The dealer had no clue it was there. Only showed us one gray valve during the PDI.
DwarfDogWalker is offline   Reply With Quote
Old 08-12-2017, 01:08 PM   #4
Thanks wouldn't happen to have a photo? I'm going to have to cut or remove the cover I want to get as close as possible
Old 08-12-2017, 01:13 PM   #5
Recently new!
Paulie1138's Avatar
My layout is similar to yours, in that the tank is located in the same location. You should not need to cut anything. You use the same drain as the other grey/ black tank. All three use the same drain, just the valve handle is located forward of the front tire, on the driver's side on my unit.....unless "the wizarding engineers" did it different on yours.
2001 Ford F-250 7.3
Old 08-12-2017, 02:11 PM   #6
rracer5's Avatar
Others above are correct. The valve should be readily visible coming out of the frame just forward of the tire as mentioned. However, IF the pull handle fell off during transport (this is known to happen a lot), then you'll have to get new one and install it (screws on). Sometimes the stem that's attached to the valve also falls off. If so, you should find a hole/slot in the frame where the stem/rod used to be. In this case, you are correct & may have to cut away a small section of the underbelly material so you can reach up and attach the new rod/handle.
Easy repair.....probably took me longer to type this than it would take you to do the repair.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 08-12-2017, 04:11 PM   #7
Crusader 295 island sink slow drain
Thanks toDwarfDogWalker, Paulie138, and rracer5. I posted a while back on an issue I was having with my battery. Then I found the battery disconnect switch by the water controls instead of by the battery go figure.
Old 08-13-2017, 06:03 PM   #8
My 315 lost the galley handle the first week. Get a new one then take all three off and loctite them to the slider mech. Threads. Also you will find that the trap setup is different than the Previous trap you are used to. Very prone to clogging.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is offline   Reply With Quote
Old 08-14-2017, 07:07 AM   #9
Fred H.'s Avatar
I had to replace the galley drain when mine broke. Found one on Amazon that worked perfectly.
Valterra TX9HPB 9" Extension Tube with Handle.
Fred n Wilma
2017 Ford F-150 EcoBoost
2015 Crusader 295RST
Fred H. is offline   Reply With Quote
Old 08-14-2017, 08:33 AM   #10
Our battery disconnect is in the same area with all of the water connections. It only kills the 12v, fridge, awning and water heater. Slide outs still work unless you physically dicconect the battery.
Old 08-15-2017, 12:10 AM   #11
GeoArm's Avatar
2013 295 rst, black and gray valve handles in basement area, galley valve handle is underneath left side just in front of the front tire. 3 seperate tanks all empty to one sewer / outlet pipe.
2012 Ram 2500 Hemi
2013 PT Crusader 295RST TE
GeoArm is offline   Reply With Quote
Old 08-18-2017, 08:53 PM   #12
crusader424's Avatar
I had two of them fall off. Ended up using loctite on the threads and threading the handles into the openings. Primetime sent me new ones. Requires patience as the opening is small but do able.
crusader424 is offline   Reply With Quote
Old 08-19-2017, 05:37 PM   #13
Recently new!
Paulie1138's Avatar
My rearward one fell off (by the tires). Discovered it when getting ready to leave. Took the one for the other tank, threaded it on, dumped....got a replacement when I got home. No big deal to thread on, just have to get the feel of when it is going on the tip, then spin it on. Yes, all three are loc-tite-d on. Also, added a safety wire type loop to keep it from spinning off ever again!
2001 Ford F-250 7.3
Old 10-18-2017, 06:00 PM   #14
LOL we must have had the same dealer because mine did the same thing and I had no idea it was there.!
5ERSTEVE is offline   Reply With Quote
Old 10-18-2017, 06:01 PM   #15
LOL we must have had the same dealer because I have the exact same issue with the exact same trailer! I thought I had a broken valve when I had the other gray water handle shut and water would still flow. Turns out my second unknown valve was just opened
295, crusader, drain, sink
