Old 04-21-2016, 07:24 AM   #1
DavidAndDonna's Avatar
Crusader 295 outside water valve leaking
the hot water valve is leaking under the trailer, I'm assuming this is the drain valve for the hot water (red).
USUALLY a valve has a packing gland and a simple turn of the nut on the top side of the valve fixes this issue however, don't seem to be a packing gland nut.
Am I missing something here or do I need to replace the valve?
Thanks!
David & Donna
Crusader 295RST
Dodge 3500 Dually 6.7 Cummins
Dodge 3500 6.4 Hemi
DavidAndDonna is offline   Reply With Quote
Old 04-21-2016, 12:09 PM   #2
another_newfie's Avatar
I assume you are talking about the low point drain. If so, it'll be easier to cut it off and put on another. A sharkbite 1/4 turn valve will do it.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
Old 04-21-2016, 02:50 PM   #3
Yes it's the low point drain on the hot water side, thx for your reply!
David & Donna
Crusader 295RST
Dodge 3500 6.4 Hemi
Old 04-21-2016, 04:40 PM   #4
Try not twisting it so much. My cold water low point drips if twisted close as far as it goes. Back it off a touch and it is fine. Well it's not done but it no longer drips.
rscconrad is offline   Reply With Quote
Old 04-21-2016, 04:49 PM   #5
WOW... thx for the advice, it worked...LOL...never considered backing off the valve...Thanks again!!!
David & Donna
Crusader 295RST
Dodge 3500 6.4 Hemi
Old 04-21-2016, 04:53 PM   #6
Glad I could help
Happy camping
295, crusader, leak, water
