Old 09-24-2012, 11:55 PM   #1
Crusader 298BHD Bypass Valves Location
Anybody own the Crusader 298BHD and know where the water heater bypass valve is located? I don't see any cabinet or panel to access.
Crusader Bob is offline   Reply With Quote
Old 09-25-2012, 07:19 AM   #2
MtnGuy's Avatar
Looks like the water heater is on street side right beside the basement. There should either be a access from the basement, or a removable panel behind the entertainment center.....open the bottom doors and check the back wall in that area.
Old 09-26-2012, 07:55 AM   #3
Thanks, will check.
Old 09-28-2012, 07:22 AM   #4
There is a removal panel right behind the hookups (water, cable, water heater) with like 2 screws that you need to take off and you will see the valves right behind the water heater
Austinjenna is offline   Reply With Quote
Old 09-28-2012, 09:13 AM   #5
Ok, thanks. I will check on Monday.
Old 09-28-2012, 09:35 AM   #6
Commercial Member
The access is by removable panel INSIDE the pass thru storage and BEHIND the off door side convenience center.
PTM
RV Guy is offline   Reply With Quote
