Old 05-18-2016, 07:39 PM   #1
Crusader 315 slide and window problem
The slide that has the recliners makes a loud pop when it's about 6" from fully open anyone else have this issue dealer trying to tell me it normal(BS) also the sliding windows by the dinette and the recliners won't open unless lube is sprayed in the track
colo native is offline   Reply With Quote
Old 05-19-2016, 07:27 AM   #2
Todouble's Avatar
I have the same model crusader and no pop when opening my slides and my dinette window slides open freely. Sounds like the slide is racked and needs an adjustment. This will most likely cure both problems
Todouble is offline   Reply With Quote
slide, crusader
