Old 07-14-2016, 06:13 PM   #21
Originally Posted by wicked1 View Post
I did not realize there were blank panels in the ceiling? I now get it,
There are NOT blank panels in the ceiling, what we replaced are the original existing vents that were not adjustable.
With the new adjustable vents you can now open or close them as you wish.
When i run both AC's I walk to the front bedroom and close down the front bedroom vent so I get more air flow in the main room.
2012 Prime Time Crusader 320RLT
2006 Weekend Warrior LE 3300
DWRAT is offline   Reply With Quote
Old 07-14-2016, 06:33 PM   #22
TURBS's Avatar
I think you two are talking about two different things here.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "14"
Old 07-15-2016, 10:35 PM   #23
I have the second AC installed in the bedroom but it was done by the dealer so itís not ducted into the main system and I wish it was since itís a 15 BTU unit. I have controls on the ceiling for the one in the bedroom; main unit is connected to the thermostat and is controlled that way. Anyone else have this setup? One AC in the summer is not enough I can tell you that for sure.
esmoglo is offline   Reply With Quote
Old 08-15-2016, 03:45 PM   #24
I have the configuration you described. I put the 2nd AC in myself. It works great and it keeps the trailer cool even on 100 degree weather. We only use the 2nd unit when it is needed.
mcjohnson74 is offline   Reply With Quote
Old 08-15-2016, 05:35 PM   #25
What make and model you guys install.
Kevin & Denise Griffin
2015 Ford F350 Super Duty 6.7 Diesel CC SB, Demco 18K Hijacker Auto Slide, Pace Edwards Electric Tonneau, TST TPMS 507 Standard Sensors, Titan 50 Gallon Midship Fuel Tank
2016 Prime Time Crusader 315RST 5th Wheel, Dometic Slide Toppers
KEG_75 is offline   Reply With Quote
Old 08-16-2016, 06:18 AM   #26
I installed a Dometic Penguin, 13,500 BTU
Old 08-16-2016, 06:36 AM   #27
I went with the matching Dometic 15k for the bedroom when I had to replace mine.
Brisk Air II - 15K - Roof Air Conditioners on Sale - PPL Motor Homes
2015 Crusader 315rst
2016 Ford F350 SRW 4x4 King Ranch 6.7L
Houstonkid is offline   Reply With Quote
crusader
