07-12-2016, 07:19 AM
Crusader 315rst 2nd AC
Anyone know if you can add a second AC to the Crusader 315? Or is the one unit enough in direct sun?
2016 F350 CREW 6.7 PowerStroke Diesel
2015 FR Rockwood Roo 23IKSSy
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
07-12-2016, 07:40 AM
Never mind read this on Primetimes site
07-12-2016, 08:58 AM
Add the second a/c you'll not be disappointed.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "14"
07-13-2016, 09:45 AM
Mine came with the bedroom 13.5k, I dinged it up and replaced it with the 15k and love it. We camped July 4th weekend in 97 degree temps and Texas humidity, the 2 AC's kept the trailer at a comfortable 70 degrees all day.
2015 Crusader 315rst
2016 Ford F350 SRW 4x4 King Ranch 6.7L
07-13-2016, 10:07 AM
Good to know if I go with the 315 I may get another 15K instead of 13.5K
07-13-2016, 10:18 AM
For sure, the price difference is really nothing between the two.
07-13-2016, 10:20 AM
No need for a 15K, it only blows in the front bedroom.
I personally would recommend a low profile unit as it will be at the high point of your trailer.
07-13-2016, 10:23 AM
Your 315 is not ducted? That is strange. Mine is ducted and both AC's are connected.
07-13-2016, 12:50 PM
2nd Air
When I purchased my 2016 Crusader 315rst it only had the single air conditioner. This unit comes with ducted air and if you purchase a new unit with both air conditioners installed at the factory both will be ducted. If you add a 2nd air in the bedroom to a unit which did not come from the factory with two air conditioners then the bedroom air will only blow in the bedroom. This is what I was told when I purchased mine. So far I have been satisfied with the performance of the single 15k air however I am investigating the addition of a 2nd air. If I add a 2nd unit it will be a low profile unit and the most quite one I can get. Hope this helps.
Kevin & Denise Griffin
2015 Ford F350 Super Duty 6.7 Diesel CC SB, Demco 18K Hijacker Auto Slide, Pace Edwards Electric Tonneau, TST TPMS 507 Standard Sensors, Titan 50 Gallon Midship Fuel Tank
2016 Prime Time Crusader 315RST 5th Wheel, Dometic Slide Toppers
07-13-2016, 01:23 PM
I would only add a low profile unit no matter what and if the first unit broke replace with low profile as well, not even sure why they bother with other units on 5th wheels but I guest the cost.
07-13-2016, 02:16 PM
Thanks for clearing that up Kevin. Mine came with the 2nd AC factory installed.
07-13-2016, 04:23 PM
Our 2013 Wildcat Sterling 32RL was wired and braced for the 2nd AC and the previous owner added the 13500 in the front bedroom. It is not ducted but the rear unit is ducted in the entire camper, even the front bedroom.
Here in S Louisiana we have never been uncomfortable even on the hottest must humid days.
Just Saying
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
07-13-2016, 06:17 PM
I have the single AC unit in my Crusader 315 and am contemplating adding the second in the BR. On our last trip the single unit would not keep up during the day. My questions are if the second unit is added:
1. can it be added to the duct work
2. if not, can the BR ducts be sealed so the rest of the RV cools better
We did notice that the Bath stayed very cool, even to the point that my DW asked me to turn off the AC when she took a shower. I guess I need to shut part of that vent.
2014 FR Crusader 315RST
2014 Ford XCabSD F250 6.7L
4x4 Lariat
07-13-2016, 06:25 PM
I installed adjustable vents in the front bed room and the bath room.
when I run both units I close off the front portion of the RV.
Round AC Ceiling Vent Fully Adjustable White New with Shroud RV camper Trailer | eBay
2012 Prime Time Crusader 320RLT
2006 Weekend Warrior LE 3300
07-13-2016, 06:46 PM
How did you know where to install them to get them connected to the duct work? Was it a big job to do?
07-14-2016, 06:01 AM
Wicked, I think he is saying that he removed the non-adjustable factory vents and replaced them with these. The round ones in his link should fit the factory holes in the ceiling.
07-14-2016, 08:43 AM
That is correct.
07-14-2016, 08:58 AM
IMO you want the bedroom a/c ducted!
If your unit is pre-wired for the second a/c the ducting is already there.
You may just have to remove a panel.
I even had a unit that was not pre wired for second a/c and it was ducted.
GO DUCTED!
Especially if you have the multi zone thermostat.
2015 Columbus 320RS
2008 2500HD Duramax
07-14-2016, 09:42 AM
X3 I did the same....and yes, they do fit in the original hole. Just get yourself a roll of silver A/C duct tape to reseal them to the ceiling ductwork.
2014 Prime Time Sanibel 3250
07-14-2016, 10:14 AM
I did not realize there were blank panels in the ceiling? I now get it, and hope to get our new 5th wheel soon just want to get the most for my Roo as some dealers are low balling us and not moving off their listed price so we will wait.
