Old 07-12-2016, 08:19 AM   #1
wicked1's Avatar
Crusader 315rst 2nd AC
Anyone know if you can add a second AC to the Crusader 315? Or is the one unit enough in direct sun?
2016 F350 CREW 6.7 PowerStroke Diesel
2015 FR Rockwood Roo 23IKSSy
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 07-12-2016, 08:40 AM   #2
wicked1's Avatar
Never mind read this on Primetimes site
Name:	ImageUploadedByForest River Forums1468327251.467537.jpg
Old 07-12-2016, 09:58 AM   #3
TURBS's Avatar
Add the second a/c you'll not be disappointed.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "14"
Old 07-13-2016, 10:45 AM   #4
Mine came with the bedroom 13.5k, I dinged it up and replaced it with the 15k and love it. We camped July 4th weekend in 97 degree temps and Texas humidity, the 2 AC's kept the trailer at a comfortable 70 degrees all day.
2015 Crusader 315rst
2016 Ford F350 SRW 4x4 King Ranch 6.7L
Houstonkid is offline   Reply With Quote
Old 07-13-2016, 11:07 AM   #5
wicked1's Avatar
Good to know if I go with the 315 I may get another 15K instead of 13.5K
Old 07-13-2016, 11:18 AM   #6
For sure, the price difference is really nothing between the two.
Old 07-13-2016, 11:20 AM   #7
No need for a 15K, it only blows in the front bedroom.
I personally would recommend a low profile unit as it will be at the high point of your trailer.
DWRAT is offline   Reply With Quote
Old 07-13-2016, 11:23 AM   #8
Your 315 is not ducted? That is strange. Mine is ducted and both AC's are connected.
Old 07-13-2016, 01:50 PM   #9
2nd Air
When I purchased my 2016 Crusader 315rst it only had the single air conditioner. This unit comes with ducted air and if you purchase a new unit with both air conditioners installed at the factory both will be ducted. If you add a 2nd air in the bedroom to a unit which did not come from the factory with two air conditioners then the bedroom air will only blow in the bedroom. This is what I was told when I purchased mine. So far I have been satisfied with the performance of the single 15k air however I am investigating the addition of a 2nd air. If I add a 2nd unit it will be a low profile unit and the most quite one I can get. Hope this helps.
Kevin & Denise Griffin
2015 Ford F350 Super Duty 6.7 Diesel CC SB, Demco 18K Hijacker Auto Slide, Pace Edwards Electric Tonneau, TST TPMS 507 Standard Sensors, Titan 50 Gallon Midship Fuel Tank
2016 Prime Time Crusader 315RST 5th Wheel, Dometic Slide Toppers
KEG_75 is offline   Reply With Quote
Old 07-13-2016, 02:23 PM   #10
wicked1's Avatar
I would only add a low profile unit no matter what and if the first unit broke replace with low profile as well, not even sure why they bother with other units on 5th wheels but I guest the cost.
crusader
