Old 06-09-2013, 09:51 PM   #1
Crusader 325 pantry door
Warning - when you open the kitchen slide be sure the tall pantry door on the right is closed all the way. Ours was not, got caught on the slide lip next to the fridge. It bent the door backward, taking it off at the bottom and middle hinges. Added a new item to the check list, pantry door closed?
18 Berkshire 34QS, 2018 Jeep Cherokee.
btritschler1437 is offline   Reply With Quote
Old 06-10-2013, 09:01 AM   #2
That door looks just like the Sanibel except that it doesn't have the twist latch on it. I'd suggest ordering a Sanibel pantry door latch and installing it.
Old 06-10-2013, 02:21 PM   #3
zs325RES's Avatar
Bummer - good heads up, thanks.
I can see this could be a real problem.
Hopefully you can repair it.
2013 Crusader 325RES Touring Edition
2018 GMC Sierra Denali HD crew/SB L5P Duramax
zs325RES is offline   Reply With Quote
Old 06-17-2013, 08:59 PM   #4
rracer5's Avatar
I guess our PDI Tech at Schaeffer RV in Hamburg, Pa. was that good (or it happened to him once). He made sure to point out such a possible issue during our PDI. But, guess what.......I did it once too. Didn't damage anything. I noticed one side of the slide had stopped moving so, I let go of the button just in time.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
