Originally Posted by RickV
I am looking for opinions on adding a bedroom ac to my Crusader 325res. If you have added one what brand\type did you install? I figure I'll go with a 15000btu with a heat strip. I have a pole barn that I store it in and have 13.5' of clearance and want to make sure it will clear.
I installed the Coleman Mach 8 because it is the lowest profile on the market. Because this AC would not tie into the other AC, it didn't matter that the brands matched. I did a 13,500 btu with the heat strip. Instructions were well written and the install was easy (other than getting it on the roof). If you have a barn, I would expect you could lift the AC up in the rafters and back under it.
