Old 09-20-2015, 11:25 AM   #1
Kelly_3700's Avatar
Crusader 335BHS JT Strong Arm Mounting
I'm going to bring up a subject I know I have seen here before but can't find it anywhere.
I have installed my front set of JT's on my Crusader 335bhs. I have been seeing different things on mounting the rear set; things like there is a cross member under the enclosure, mount them forward, mount the backward, install a cross member. I don't see or feel a cross member under the panel. So I am planning on mounting mine from the electric jacks behind the tires toward the rear of the coach right to the frame. My question is, has anyone mounted this way and did you see a difference mounting front to rear?
Kelly_3700 is offline   Reply With Quote
Old 09-22-2015, 05:25 AM   #2
Toy-aholic
take a few of the screws holding the underbelly out, use a flashlight & you'll find the cross member.
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 09-22-2015, 06:52 AM   #3
Kelly_3700's Avatar
The cross member is right in line between the 2 jacks. I found it. But with the jacks being so far forward(behind the tires) it did not do much for movement in the bunk area when I mounted them there.
Old 09-22-2015, 07:53 AM   #4
Here is a little info.
Goodbye LaCrosse.....Hello Crusader!
2015 Crusader 315rst
2016 Ford F350 SRW 4x4 King Ranch 6.7L
Houstonkid is offline   Reply With Quote
Old 09-22-2015, 05:53 PM   #5
Toy-aholic
I have the same thing but I think the movement is from the leverage the slide has when someone is in the bunk or couch....a jack under that slide may help that.
Old 09-22-2015, 07:25 PM   #6
Kelly_3700's Avatar
I ended up relocating mine from the cross member between the jacks to going from the outside of the jack to the rear 30". I mounted it as far on the inside of the frame rail as I felt safe. It is at about a 12-15* angle and seems to work a lot better than between the jacks.
Name:	ImageUploadedByForest River Forums1442967617.310098.jpg
Name:	ImageUploadedByForest River Forums1442967798.244194.jpg
Old 09-22-2015, 07:27 PM   #7
I just got me some 1 1/2" square tubing and made a cross member. Would post pic but camper is in the shop now to have a slide wall replaced.
10 Chevy Silverado 3500 CrewCab
6.6L Duramax with EFI Live Tuner with 5 levels
560hp 958 Max torque 3:73 gears
2015 Crusader 351REQ
cajun225 is offline   Reply With Quote
Old 09-23-2015, 05:30 AM   #8
Toy-aholic
I was going to do the same thing until I found the crossmember between the jacks
crusader, mount
