Old 07-03-2014, 05:13 PM   #11
Well that's good, if that was the problem then press your "easy button"
Keepaeyeonit
2014 Crusader 335BHS-TE
2017 F-350 6.7L CC flat bed
Nights Camped in this unit.
2017 3 so far
2015 57/2016 52
2014 40/2013 38
keepaeyeonit is offline   Reply With Quote
Old 07-05-2014, 09:08 AM   #12
Toy-aholic
Angry
update...problem still there and bad as ever....maybe a mouse chewed a hole through the top of the tank? Got an appointment at the dlr after we get back from our trip to ck it.....going to be a long stinky week!
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 07-22-2014, 05:56 PM   #13
Well how did you make out with your smell or has it still not been taken care of yet? Keepaeyeonit
2017 3 so far
2015 57/2016 52
2014 40/2013 38
Old 07-22-2014, 09:17 PM   #14
Toy-aholic
very strange, went for a week vaca 2 different places and after the first good flush smelled nothing. Now that it's been sitting for over a week I can smell it creeping back??????? Frustrating
The kicker is I canceled an appointment with my dlr thinking it fixed itself!
Old 07-22-2014, 09:36 PM   #15
irishrv's Avatar
If you check under the bathroom sink or kitchen sink is the smell stronger? If so there is a cap on the end of a pipe near the sink drain. It is called an air admittance valve and it needs to be replaced. $9 Home Depot.
2014 295rst champ te
2009 2500hd GMC d/a
2014 295rst TE Champagne
09 GMC 2500HD D/A
irishrv is offline   Reply With Quote
Old 07-22-2014, 09:53 PM   #16
Toy-aholic
2009 2500hd GMC d/a
first place I checked...nothing.
Old 08-07-2014, 07:26 PM   #17
Did you find the source of the odour? Just curious as I am interested in this unit.
2012 Coachmen Freedom Express 292BHDS
2009 Ford F250 Super Duty CC 6.8L 4.10
Husky Centreline WDH w/Sway Control
2013 Nights Booked: 38
2013 Nights Camped: 40
pwrplay is offline   Reply With Quote
Old 08-07-2014, 07:36 PM   #18
Had a real bad odor in mine also. Took it to a repair shop after I drained and cleaned the black tank good. Checked the vent in the tank, it's ok. Next thing he did was take fill the black tank and toilet up to the rim and let it sit to see if there any leaks. All good. Figured the problem was I was not starting out with enough water. Should be 3 to 5 gallons, enough to cover the solids with water and allow the chemicals to work. Problem solved.
Started Out With Nothing,
Still Have Most Of It Left!
jwedell is offline   Reply With Quote
Old 08-07-2014, 07:51 PM   #19
That is what I always do. After I dump and flush, I pour a 10L pail of water in the tank with 2 cups of Calgon softener diluted in the pail water. Keeps the walls nice slick so no sticking.
Old 08-08-2014, 08:15 AM   #20
Toy-aholic
seems to be coming from the galley tank...going to check the venting when I get home from vaca. may have a nest or something blocking it.
crusader
