Old 06-30-2014, 05:48 PM   #1
Toy-aholic
Crusader 335BHS odor patrol
Been having a nasty sewer odor lately in the bathroom area. Flushed tank 3x and took care of it for that weekend....now it's back...checked vent- clear...opened basement doors and damn near get knocked over...took the rear panel off the basement to gain access to the area where the toilet drain & vent pipe penetrate the floor. Zero signs off any moisture on any pipe connections but getting my nose as close to the floor holes as possible and really get it! (stench) Dropped the belly pan and also got the smell...NO signs of leaks. Got an appointment with dlr in a couple weeks...any other 335 owners getting this issue?
2005 GMC Sierra 3500 SLT DRW 6.6 D/A FOR SALE
2013 Crusader 335BHS TE FOR SALE
EXGMTech is offline   Reply With Quote
Old 07-01-2014, 03:06 PM   #2
I would make sure the seal on the flange is good,its possible its not leaking water(it would not leak unless you fill the tank above the floor line) but the oder will leak.I would look at the seal first because you don't see any sign of a black water leak,I keep at least 5 Gal of water plus add tank treatment after I wash out to help keep the tank clean(and oder free) as your driving the water will splash around inside the tank. Keepaeyeonit
2014 Crusader 335BHS-TE
2001 F-350 DRW CC 7.3L
Nights Camped in this unit.
2016 51 so far
2015 57
2014 40/2013 38
keepaeyeonit is offline   Reply With Quote
Old 07-01-2014, 04:42 PM   #3
Wiscampsin's Avatar
You said you checked the vent and it is clear. While up on the roof did you check to see if the vent pipe slid down and is sitting on the bottom of the tank? If it did the pipe isn't venting anything.
2013 Palomino Sabre 34REQS-6
Link to pics:http://s1340.photobucket.com/user/Wi...?sort=4&page=1
Old 07-01-2014, 05:05 PM   #4
Toy-aholic
I have about 1.5" of pipe sticking out...when I was in bsmt I grabbed the vent & tried to move it...it didn't
Old 07-01-2014, 05:07 PM   #5
Toy-aholic
I can not even see the top of the tank let alone any seals
I do the same as you for travel cleaning
Old 07-01-2014, 06:08 PM   #6
You probably can't see it,you may have to remove the toilet and just replace the seal,this is not a recommended way but you could fill the black tank until the water is coming up into the toilet bowl but if the seal is leaking that will make a mess so put down towels if you go that route but check this link first, it could be a few things causing it!
http://www.dometic.com/ca179a93-1151...1f3ee1ba.fodoc
Keepaeyeonit
2016 51 so far
2015 57
2014 40/2013 38
Old 07-01-2014, 06:29 PM   #7
Another case of the bad model 300 toilets from Dometic?
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 07-01-2014, 08:30 PM   #8
Todouble's Avatar
I was gonna suggest maybe dometics toilet that has the recall. Model 300 if I remember. They've updated to the 310 I think. It's all over the forum. Just a guess but this may be your prob. Goodluck
Todouble is offline   Reply With Quote
Old 07-01-2014, 08:34 PM   #9
Toy-aholic
Bob
I checked that first, mine's a 310
Old 07-03-2014, 05:25 PM   #10
Toy-aholic
Ok I'm a flip'n idiot! Solved it myself, I think....the toilet bowl was dry...I always empty before travel so as to keep it from splashing out...forgot to refill. Added 3" of water and the next day odor gone!
We're heading to WA DC then VA this week...will be a good test.
What an idiot!!!!
crusader
