Old 07-21-2013, 09:54 PM   #1
Crusader 335BHS - trip report
Just wanted to pass along some experiences with our Crusader 335BHS on our first 'real' trip out with it....
Spent our first 3 nights at Hartwick Pines State Park (Grayling, MI) - nice, quiet park. Had a site with full hookups. Made the 3 hour trip with a full fresh water tank - actually pulls better with a full tank and loaded for a week long trip. Got 12 MPG pulling also. Temps were in the upper 80's and humid, the single AC did a good job keeping the whole rig cool. Only one real issue with the Crusader - the auto-leveling system wanted to lift the tires off the ground again to level the rig (on a flat, paved, level site). After some serious analyzing and a few beers, I finally figured out the issue: my Crusader rides nose-high when hitched to my truck, and when I was arriving at camp to unhitch I was pulling the pins to manually extend the front legs down onto 6x6 boards. Then, I would use the leveling system to electrically raise the front of the coach a bit to unhitch. Once unhitched, I would also pull the rear pins and manually lower the rear legs onto boards and then push the auto-level button. The problem is that because I did not power-extend the front jacks before unhitching, I could never lower the front of the coach to level - so, the auto-leveling system had to raise the back end to get to level, raising the tires off the ground. So, what I do now is prior to unhitching, power-extend the jacks about 3 inches then pull the pins and drop the legs down onto the boards. Then, raise the front of the rig a bit to unhitch. Once unhitched, I can lower the front down to about level, extend the rear jacks, and then auto-level. Works without lifting the whole rig off the ground!!!
After 3 nights at Hartwick Pines, we headed another 3 hours north to Tahquamenon Falls State Park - had a site in the Lower Falls campground backed right up to the river. Nice level, dirt site - and used the method above the rig leveled itself perfectly (with tires on the ground). The mosquitoes were HORRIBLE.... Had to replenish my blood supply with a few more beers! Again, hot and humid weather but the AC kept up. 2nd night there we had a big rainstorm - our site was sitting in 2 inches of water for a bit. No leaks though! Did find that our galley gray tank handle fell off somewhere - 2nd time we lost it, first time was in the storage lot but I found it that time. Sent Prime Time a request for another handle and recommend they lok-tite them during assembly (which I will now do). This specific handle hangs out like a propeller under the coach - and, it's a PITA to reach into the hole in the frame to grab the rod with pliers to open/close the dump valve. We had another big storm blow through a couple nights later - again, site flooded even worse and the campground lost power around 8:30PM. Power came back on about 3AM - battery was still on full, fridge switched to propane without issue, no complaints. Overall, we were very happy with the Crusader - very comfortable, tons of storage, no real issues with any of the systems (except the soundbar radio reception is terrible), and we received many compliments.
After 5 nights at Tahquamenon Falls, we left for the 6 hour ride home... Again, camper pulled great even during a hard rainstorm. We did lose the spare tire cover somewhere along the way...
Overall - a great trip, and we were very happy with the Crusader! Next stop, Platte River campground and Sleeping Bear Dunes.....
Rig: 2011 F350 CC SB FX4 diesel, aka The Tow Beast
Summer House: 2013 Prime Time Crusader 335BHS
hockey dad is offline   Reply With Quote
Old 07-22-2013, 07:25 AM   #2
Wildwood Danny's Avatar
Sounds like you had a great camping trip with all of the real life camping adventures and memories, bugs, rain, temp with a few minor RV problems being included and most worked around or solved. If all RV trips were perfect we wouldn't have a lot of the threads on this forum site.
On the dump valve handle, switch it out to a metal one with the thread lock (won't break off when pulling or pushing it). Also can use a jam nut to keep it from unscrewing.
Again, sounds like a great trip in the Crusader.
2006 Silverado 2500HD Duramax
2010 Prime Time Lacrosse 303RKS
2007 Hensley Arrow Hitch
PT Crew Member 125
Good Sam Club, Cedar Creek Sams Chapter
Passport America Member
Wildwood Danny is offline   Reply With Quote
Old 07-23-2013, 05:16 PM   #3
been hearing a lot of the dump valve handles....going to Loctite mine now!
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
