I also had the issue filling the FW tank - I've read here that many have with Crusaders.
Originally Posted by another_newfie
ABBREVIATED: The tank will not fill all the way.... If there is a low spot or improper routing you won't hear it. It is quite obvious if it isn't working the way it should.
Very true. Before I fill, I simply blow back into the vent with a small tube thingy I made which clears the line, then I have no issue getting it full.
