Old 05-20-2015, 08:48 AM   #1
crusader 5th wheel. landing gear switch
Last weekend when hooking up to the truck my landing gear did not want to retract.I pulled the switch out and diconnected the wires and thought i reconnected in the same spots.The switch will still only function in one direction,I can reverse the red and black wires that go to the motor and reverse the direction but not with the switch.Yesterday I. went and bought a new switch and same result.I am looking for some one to tell me which wires to which terminals.
articrhinocat is offline   Reply With Quote
Old 05-23-2015, 05:24 PM   #2
Send a message via MSN to Tiggerdad
Switch on mine did the same. Took it apart and one side was corroded. Cleaned it and reinstalled. With the switch installed and looking from under the camper my wires are:
Both reds on right side. Both blacks on left side. Can not tell you which wire raises and lowers but if it doesn't work swap the reds from top to bottom and try. If that doesn't work. Try swapping the blacks. Good luck.
Check to see if you have a blown fuse. My inverter has all the lights lit upon when all is well. No light means blown fuse.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
5th wheel, crusader, wheel
