Old 02-18-2016, 06:56 AM   #21
Justice12t's Avatar
Dealer got a hold of me yesterday. They put a request into lippert about either welding in approved bumper supports or attaching a lippert product to the back that won't cause any warranty concerns. We will see what happens. And my basement is not big enough for bikes and gear.
2016 Prime Time Crusader 294RLT
2021 RAM 3500 Laramie Mega HO\CTD, CC, 4x4...ect
Days Camped in last 3 years - 79
Planned Days in 2021 - 50
Days Camped in 2021 - 0
Justice12t is offline   Reply With Quote
Old 02-18-2016, 03:01 PM   #22
rracer5's Avatar
Better safe than sorry later.
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 06-19-2016, 07:51 AM   #23
Anyone know the exact size of this rack?
SkeetnKathy75 is offline   Reply With Quote
Old 06-19-2016, 08:03 AM   #24
TURBS's Avatar
70" x 25"
Sent from my SCH-R530U using Tapatalk
Old 07-31-2016, 07:12 PM   #25
sji
Justice 12t, wondering what you ended up doing for your bike carrying needs. Did Lippert ever respond to your request?
sji is offline   Reply With Quote
Old 08-01-2016, 07:44 PM   #26
King of the Road
Along these lines I have a small motorcycle (250 lbs) that I would like to haul on the back of my 27RK. The dealer gave me the name of a certified hitch shop to have the receiver added.
Does anyone see a problem with 400 lbs of receiver, ramp and dirt bike causing any problems?
2016 Crusader Lite
Single slide
2013 Ram 2500 Crew Cab Tow Vehicle
2016 days camped = 91, 2017 days camped = 109
Dano1955 is offline   Reply With Quote
Old 08-01-2016, 08:56 PM   #27
TURBS's Avatar
I see lots of problems, however most people don't head warnings and do it anyway.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "22"
Old 08-01-2016, 09:16 PM   #28
King of the Road
Well OK. Not helpful though without a little more information. My dealer did not see a problem, but he didn't elaborate on anything either.
Sent from my LG-H830 using Tapatalk
2016 Crusader Lite
Single slide
Old 08-01-2016, 09:20 PM   #29
TURBS's Avatar
Crusader Back Rack(Bike) Opinions...
Ask your dealer if adding any type of hitch or rack assembly voids your frame warranty.
Furthermore any camper with a lite or ultra light designation use a Tin can fabricated I beam that will fold with that kind of weight.
If I had to guess its probably a 6" welded together pretend I beam.
2015 Columbus 320RS
2008 2500HD Duramax
Old 08-01-2016, 09:23 PM   #30
King of the Road
Originally Posted by TURBS View Post
Ask your dealer if adding any type hitch or rack assembly voids your frame warranty.
2015 Columbus 320RS
2008 2500HD Duramax
I did. They said not if certified welder put receiver in, and they referred me to "their" certified company. Apparently they have used them many times.
2016 Crusader Lite
Single slide
Old 08-02-2016, 08:31 AM   #31
TURBS's Avatar
Yeah I wouldn't take your dealers word .
2015 Columbus 320RS
2008 2500HD Duramax
Old 08-02-2016, 09:13 AM   #32
King of the Road
Well have it in writing (email) and they will be handling warranty work so I'll go with the known entity. But will put a call in to Prime Time/Lippert for your peace of mind.
2016 Crusader Lite
Single slide
Old 08-02-2016, 09:31 AM   #33
TURBS's Avatar
Thanks [emoji6]
2015 Columbus 320RS
2008 2500HD Duramax
Old 08-03-2016, 07:21 AM   #34
Justice12t's Avatar
Sorry for the delay...just noticed the new posts...
My dealer responded with about the same statement...certified this and that...
I used this ---> https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
My bumper is attached via 6 inch box channel to my I beam frame. I bolted the above onto the box channel with grade 8 bolts and had my buddy (Certified Master Welder) tack the top of the bracket to the bottom of the I beam. Easily grind-able if I needed to remove and a little extra piece of mind.
I only use it for a 4 bike carrier with a hitch clamp to stop any bouncing. It really works great, 3000 miles and counting...
I looked at a few others but they would not work with my setup without other modifications...
**Word of caution...the brackets will hang fairly low and yes they will scrape from time to time Only twice actually so far...(Not while traveling down the road)...I have been on some pretty good incline in gas stations and what not and they do hit but don't dig in, I just take things slow or at different angles when I feel I need too**
bike, crusader
