Old 03-05-2012, 08:09 AM   #11
rracer5's Avatar
Originally Posted by Crusader View Post
not that I am seeing.....
Damn...... Another thing is the backlight is so bright that it makes it difficult to read the display (time etc.) from a distance. Kinda makes the remote useless cause I can't see the display from the comfort of my rocker due to the backlight.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 03-05-2012, 08:47 AM   #12
I installed a toggle switch in the main power wire for the radio.
2004 GMC Sierra 2500
2012 Primetime Crusader 298BHD
sbelliott is offline   Reply With Quote
Old 03-05-2012, 06:03 PM   #13
DF5.4's Avatar
Mine is an AWM970. Different setup.
Doug
2011 Prime Time Tracer 3000BHS
2007 Ford Expedition
Reese Dual Cam HP Hitch
Nights Camped 2015-5 in TT
DF5.4 is offline   Reply With Quote
Old 03-05-2012, 06:14 PM   #14
Crusader's Avatar
Called jensen today.....They told me that there is no way to turn back light off. I would have to wire in a toggel switch like (sbelliot) did. Jensen said use the solid red wire on newer units or the red/white wire on older units. This wire will only turn off the power to the back light.
Crusader is offline   Reply With Quote
Old 03-12-2012, 10:57 AM   #15
LKicklight's Avatar
Light In Radio
Got the same problem in our 270RET...thought about taking the unit out, and replacing bulb with something smaller or putting a tint cover over it..
Will check it out and see what is involved..
LKicklight
LKicklight is offline   Reply With Quote
Old 03-12-2012, 10:59 AM   #16
LKicklight's Avatar
Light In Radio
Hello Tom, will we ever get these bugs out of our coach's...the light bugs me being on all the time..one day it will have to burn out....might try taking the radio out and repalcing the bulb with an LED...
LKicklight
Old 05-31-2012, 02:09 PM   #17
Realize your discussing the radio display. However, I use black nail polish on LED lights in our bedroom electronics. Such as the power standby on the TV and cable box. Problem solved.
wrarmykeys is offline   Reply With Quote
