07-17-2011, 02:19 PM
Digital Thermostat Setting
I've had the tt plugged in the last couple of days so I could run the AC. Temps have been in the mid 100's and I wanted to see how well it would cool the tt. Even with the tt under cover the AC has ran constant during the day.
The fan AUTO setting runs the fan on LOW whenever the actual room temp is within 4º or less than the set thermo temp. The LOW fan setting can't keep the tt cool in these temps.
So the AC fan automatically switches to LOW when it gets within 4º of the set thermo temp, but the temp will rise above the 4º difference with the fan on LOW, so then it will switch back to HIGH, cool back down etc..., but it will never reach the set thermo temp when back on LOW.
This morning I set the fan to HIGH and it is keeping the trailer much cooler so far. Of course the fan runs constantly now, but the AC compressor does cycle on and off.
Right now the outside temp is 103.8º. I set the thermo at 78º. The living/kitchen area, where the AC is located, is at 76º and the front bedroom is at 79º. The thermo is located in the hallway close to the bedroom.
Just thought I would post this info just in case it might help some of you experiencing the same in these hot temps.
Picture of Dometic Digital Thermostat
07-18-2011, 07:21 AM
Mine is working hard too, with 30+ days of 100 or better, runs alot to keep up with the heat. We set it on 77/78 and on high during the day and 69 or so at night on low, it gives the A/C a break...hehe!!
2012 GMC 2500 HD
2011 303 RK LaCrosse Luxury Lite
Days camped 2010: 274
2011: 365
2012: 365
07-18-2011, 07:27 AM
Gary, last winter you sent several of the cold spells and snow this way. Now you are doing it with the heat. How about turning that big fan OFF !!!!
07-18-2011, 07:32 AM
It's a deal., ONLY if you turn your's on and send some cooler temps down this way!
07-18-2011, 07:42 AM
Too late, it is already getting hot here.
07-18-2011, 08:23 AM
You probably meant LOW 100s, as you would not be here to talk about it..
Denis & Diane
* Happy Campers *
07-18-2011, 10:41 AM
Yeah, my bad. Yesterday was 104.2 degrees. I was thinking mid way between 100 and 110!
Yep, the heats gettin' to me!
07-22-2011, 12:59 PM
Gary, are you sure you turned that big fan off ???
Geez, it just ain't a supposed to get that hot here. This is not the desert southwest, Florida, or the plains. This is the Virginia Blue Ridge moutain foothills.
That was the maximum for the day, I hope. It is down to 102 right now.
07-22-2011, 01:07 PM
CLASS "A" Senior Member
It's not very often you hear on the radio that the 4:00 AM temperature had cooled down to 90 degrees.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
07-23-2011, 07:32 PM
We left the N.E. Oklahoma FROG Rally a day early because of the heat. When we got home at about 5pm the temp was 104.2º. I guess we jumped out of the skillet into the fire!
07-23-2011, 08:04 PM
It's miserable here too. The kids didn't even want to play in the sprinkler. It's the 150th Anniversary of the Battle of First Manassas/Bull Run and there are thousands of reenactors in full period dress - which means wool uniforms in 100+ degree weather. Just thinking about it makes me start to sweat. Ugh.
Chris, Karen and the 3 boys
2011 Rockwood Roo 233S
2008 Sequoia 5.7L
Manassas, VA
2011 camping days booked - 18 and counting
07-23-2011, 11:51 PM
I think I had read something about this on another thread and tried it too. You are correct, high will cool better. I usually start on high when we set up to cool things down then switch to auto at night.
2011 Cedar Creek 36RE
2002 Ford F350 Crew Cab 4x4
