Old 04-19-2015, 11:15 AM   #21
Left Coast
Originally Posted by OldCoot View Post
I was told by the Dish technician to point the handle North.
X2
Old 04-19-2015, 11:16 AM   #22
bubbles's Avatar
I use a cheap hand held ball compass to see which direction is south and set the sat antenna down holding the handle while looking at the southern sky. My instructions say to position antenna with a clear view of the southern sky (that puts the handle of course facing north). There are 3 satellites needed for HD and only 2 needed for SD (sometimes trees prevent HD). Have never had to be precise, unless trees are an issue to get lock-on and then just slight adjustments are made. The whole dish thing is easy and reliable.
Old 04-19-2015, 03:20 PM   #23
DKRITTER's Avatar
Programing the remote
I used one of the Emerson settings to get most of it to work
Couldn't get the Mute to work though. I got on line and found this on the dish site; 20/21 Remote
Sad thing is this also didn't work.
I can get the volume to work now and turn on/off the TV.
DKRITTER is online now   Reply With Quote
Old 04-23-2015, 12:21 AM   #24
I have had a tailgater for 5 or 6 years with the
211K receiver. I have found that if the receiver is not used for a couple of months that I always have to call Dish and get them to send a reset signal before I can see all my channels. As mentioned above, they have me go through the complete setup before they finally give in and reset it, but once they reset, it happens almost immediately. I've never had anyone to come out or charge me to get it going again. Depending on how far away from home you are, you may lose your local channels. We are TVaholics so it's one of the first things we set up when we arrive at camp. Satellite AR application is free for Android phones but Dish satellite numbers don't correspond to numbers on app. With the tailgayer you just set it on flat surface with handle pointed north with a southern exposire and turn receiver on. You answer a couple of questions on the screen and the system does the rest. Usually takes about 10 minutes and you're watching your favorite channels.
rrickett is offline   Reply With Quote
Old 04-29-2015, 07:36 AM   #25
DKRITTER's Avatar
Ok we purchase a 211Z and the new style tailgater and are not real happy.
We are having consistent problems with signal loss, when we change channels it usually pops up with a screen and says signal loss.
We have tried repositioning the tailgater several times (clear view of the southern sky) and have rescanned several times and it does not improve.
Is this normal or did i get a poor system?
Old 04-29-2015, 07:41 AM   #26
TURBS's Avatar
How long do you have signal loss?
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-29-2015, 09:46 AM   #27
DKRITTER's Avatar
Usually several minutes.
Old 04-29-2015, 09:52 AM   #28
TURBS's Avatar
Hmmm.
Doesn't seem right.
TURBS
Old 04-29-2015, 10:05 AM   #29
TURBS's Avatar
Try hooking the sat dome coax right to the receiver and see if it still does it.
TURBS
Old 04-30-2015, 12:16 PM   #30
buffalohunter's Avatar
DKRITTER -
I had an issue like that in the past and called Dish Tech Support. They sent a fix via satellite to the receiver that solved the issue for me. If the tech says they don't know about that request a mobile (RV) Tech - there is or was a difference in knowledge by RV techs vs the general techs.
Good Luck,
Jim
2012 Rockwood Windjammer 3008 W
2007 Tundra Reg Cab 4X4 SR5 5.7L
buffalohunter is offline   Reply With Quote
