Old 08-17-2017, 06:14 PM   #1
Does anyone know the wire gage for 12 volt cigarette plug behind the TV? 2018 315RST
Trying to install a small 8 inch sub behind but need a 8 gage 12 volt positive. Thoughts?
mikeah007 is offline   Reply With Quote
Old 08-17-2017, 06:14 PM   #2
Kenny kustom's Avatar
No.
Go to the battery.
2017 Dynamax Isata 4
Old 08-17-2017, 06:16 PM   #3
Originally Posted by Kenny kustom View Post
No.
Go to the battery.
Can you feed a wire from the battery to behind the TV which is on a slide?
Old 08-28-2017, 07:47 PM   #4
GeoArm's Avatar
What is that used for?
2012 Ram 2500 Hemi
2013 PT Crusader 295RST TE
GeoArm is offline   Reply With Quote
Old 08-29-2017, 09:10 AM   #5
I need to install a subwoofer directly to 12 volts but require a high amp wire.
Old 08-29-2017, 09:21 AM   #6
FrankG's Avatar
Some of your fellow campers at the campground will not like this!! But, if you are going to the dunes with like minded friends you will enjoy it.
Once you get the wire pulled to the battery you will need a stout converter to keep up with that amperage draw. There should be a movable wire-way under the slide to route the wire.
Make sure the unit is well grounded. If not it could mess with the rest of the electronics. I would tend to run a separate ground (neutral) at least to the frame.
2018 Haulin 6 x 12 Cargo Trailer by Forest River (A legal Tow )
2017 Laredo 325RL
2016 Vengeance 29V Sold
2016 Ram 2500, 4x4 Laramie CCSB 6.7 Cummins
FrankG is offline   Reply With Quote
Old 08-29-2017, 09:31 AM   #7
How much current does the amplifier inside the sub-woofer draw?
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 08-29-2017, 05:55 PM   #8
It draws 20 amps and my intent is not to play loud just to round out listening to music softly.
Old 08-29-2017, 05:55 PM   #9
Old 08-29-2017, 06:08 PM   #10
Flybob's Avatar
A sub can be placed anywhere there is room. It may be easier to place the amp and/or sub in a non-slide location.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-29-2017, 06:10 PM   #11
Yea I think it will be easier to just buy a 110 plug in small sub and locate it beside the entertainment system and forget about 12 volts.
12 volt
