Old 05-18-2016, 09:57 PM   #21
bubbles's Avatar
Actually, that particular solenoid doesn't have a reference designator. I believe all BJ's are jumpers; at least according to the ref designator box. Anyway just thought I would comment.
Old 05-18-2016, 10:35 PM   #22
Your right. I tried to show a better view of it by copying a portion of the sheet 5 pdf but it would not work, sorry. It is located in a compartment behind the rear tires on the passenger side along with those big fuses and 12 volt circuit breakers.
garythelen is offline   Reply With Quote
Old 05-19-2016, 01:03 AM   #23
benagi's Avatar
Does battery charge with disconnect flipped?
Originally Posted by TURBS View Post
What speculation?
If the battery is disconnected it cannot and will not charge period [emoji17]
I've seen this question in the past. May be different for motor homes. Our 3171 will charge with the coach battery disconnect in the off position when the main engine running or on shore power. I know, I have checked with a volt meter.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 05-19-2016, 03:44 AM   #24
Witch Doctor's Avatar
I do not doubt that is a way a MH works, but my question to you is why have a disconnect? Maybe storage?...I know mine will not charge with the disconnect pulled. But I did have parasites that I put SPST switches at, because they would drain my batteries even with the disconnect off....
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-19-2016, 05:31 AM   #25
Originally Posted by garythelen View Post
Mine does. Both battery banks will charge and several other circuits are still live with the disconnect activated. And the chassis battery will charge with the chassis disconnect activated. See the attached drawing.
You are right. apparently a lot of loads on your coach work with the disconnect pulled. Strangely your converter/inverter is always live, which is kinda strange, but I guess that was the only way to make the converter work with the disconnect off, but it is prone for discharge if the inverter is left in the on position.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 05-19-2016, 06:21 AM   #26
bubbles's Avatar
Yes, storage but some items still require monitoring due to their nature (safety perhaps). Also I believe there is a legacy reason for the disconnect in that when shore power is available to prevent over charge and boil out. Of course this is not necessarily an issue due to todays converters. JMO
Old 05-19-2016, 06:21 AM   #27
TURBS's Avatar
Yeah but this ain't no Moho
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "5"
2015 nights camped "34"
Old 05-19-2016, 06:45 AM   #28
If disconnect is off they won't charge.
2008 2500hd Duramax
2015 Columbus 320RS
I would add,If the Disconnect is "Wired Properly" your battery will power "Nothing" and will NOT take a Charge! Youroo!!
Old 05-19-2016, 07:13 AM   #29
W5CI's Avatar
I am totaly confused by this discussion about battery disconnect. If the disconnect switch is switched off NOTHING should work Period. If stuff still works the disconnect is not a disconnect, if you cut a wire the current will not flow no matter what. if some manufactures are putting disconects in that dont disconnect ,they are just wasting time and money. IMHO
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
W5CI is offline   Reply With Quote
Old 05-19-2016, 07:28 AM   #30
It really depends on where in the line of things the disconnect switch falls. If there are items connected to the battery that are in front of the switch, then those will work regardless if the disconnect switch is on or off. In addition, if the line charging the battery is in front of the switch, then the battery would charge regardless if the switch is on or off.
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Asrabbit is offline   Reply With Quote
Old 05-19-2016, 07:28 AM   #31
KyDan's Avatar
Some battery switches do not shut off everything on some rigs.
The logic there is up to the designers who aren't always logical at all....
As you can see by reading this thread there are all different ways to wire a
"disconnect" switch.
Me-personally- when I shut off the batteries I want them connected to
nothing inside the trailer- period.
So I added my own Blue Sea battery switch at the battery box.
They are relatively easy to install and I've put one in every trailer I've owned.
(I should have bought a bulk pack of them years ago!!)
Motor coaches and others with engine start battery and house batteries and generators aren't quite so easy and thus the multiple answers to what at first glance seems a simple question!
Happy Trails!
Peace!
Dan & Rita D
Old 05-19-2016, 07:30 AM   #32
bubbles's Avatar
As stated, some items are fused directly off the battery but require a switch to activate that item (levelers/awning etc.) and therefore, technically, they are not putting a drain on the coach battery whether disconnected or not. In some installs there are items that have been deemed necessary to be powered even when disconnect is actuated (LP/O2 etc.) but would require minimal millivolt drain on battery. Evidently it is a crap shoot as to what each RV does when it comes to battery disconnect functions. As also stated take your volt meter and check your battery in each state of configuration and then you'll know what is what.
Old 05-21-2016, 10:49 AM   #33
Ham Camper's Avatar
I bought a marine battery shut off switch and mounted it on the A-frame right next to the battery. Now when I leave the trailer in storage for a while and come back I just flip the switch and power up. No more dead batteries from things still drawing juice when all switches are off.
Larry W8PO & Lori N8IHJ and Louie the wonder dog
2014 Surveyor Cadet 265RLDS
2015 GMC Denali HD
Ham Camper is offline   Reply With Quote
Old 07-05-2016, 02:58 PM   #34
King of the Road
My battery charges and landing gear are functional with the factory disconnect. Nothing else, which works perfectly for me. Wouldn't have it any other way
2016 Crusader Lite
Single slide
2013 Ram 2500 Crew Cab Tow Vehicle
2016 days camped = 91, 2017 days camped = 109
Dano1955 is offline   Reply With Quote
battery
