05-17-2016, 03:52 PM
Does battery charge with disconnect flipped?
So, the question came up about the battery disconnect on my Crusader 296bhs.
I'm of the understanding that the batteries will charge even if the disconnect is flipped (e.g. no lights inside the RV can turn on).
Someone was suggesting my batteries wouldn't charged and I disagreed. My rv is in storage, so I can't check.
What do you all think?
2014 Crusader 296BHS
2015 GMC 2500HD Denali
05-17-2016, 03:59 PM
If disconnect is off they won't charge.
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "5"
2015 nights camped "34"
05-17-2016, 04:04 PM
I should note that my landing gear do work with the disconnect flipped. That's why I'm assuming the power will also charge the unit.
I may be wrong, as this has come up because my trailer was plugged in over the winter but my batteries were flat this spring and the disconnect was flipped. I didn't plug in the trailer so I can't confirm it was plugged in other than take their word for it.
05-17-2016, 04:07 PM
Landing gear and or slides are hooked directly to the battery thus bypassing the battery disconnect
05-17-2016, 04:10 PM
There's no possibly way to charge the battery if it's disconnected sorry [emoji6]
2008 2500hd Duramax
2015 Columbus 320RS
05-17-2016, 04:11 PM
Doh. -1 for me. I'm glad I didn't chew them out too bad for the batteries being flat. They did a battery test and said they are ok. These are deep cycle 6v so I hope they are right.
05-17-2016, 04:12 PM
[emoji482]
2008 2500hd Duramax
2015 Columbus 320RS
05-17-2016, 05:19 PM
Depends on your specific unit. On my Georgetown they will not charge with the batteries disconnected, although as others have pointed out, even disconnected there are a number of loads that are still connected. Frankly I may change that when I connect my solar charge controller and there is no real reason for it to work that way. all it takes is moving a lead from the converter to another post on the disconnect.
2015 335DS
05-18-2016, 11:20 AM
Battery Disconnect
[[B] So when is battery turned off?
05-18-2016, 11:39 AM
The usual answer is never completely. BUT you can make it so by mounting a battery disconnect device to the negative terminal and making sure nothing is left connected directly to the negative terminal.
Like this:
Note that the RED cable is connected to the negative post in this picture which is generally not correct...guess someone ran out of black cable!
________
Cam
2015 Georgetown 280DS
05-18-2016, 11:44 AM
The main reason for the battery disconnect is to remove parasitic loads. This can be stuff that's "always on" like the CO detector and possibly the fridge, as well as for errors like mistakenly leaving an inside light or the radio on.
Landing gear isn't normally an issue because they normally have a switch that you can't "leave on." Same with slides and jacks. Also with the brake switch.
2011 Traverse LT, 3.6L, FWD
05-18-2016, 11:48 AM
When the battery disconnect is engaged (disconnected) it typically is wired that all parasitic draws (things that consume power all the time) are off. It's OK to have things like the jacks and stabilizers always connected because they only draw current when in use (push a switch) and as such, won't drain the battery.
EDIT: sorry rockfordroo... typing at the same time!
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=86
05-18-2016, 12:19 PM
larryandamy
Don't speculate...
Just find out how your rig is set up.
Take a voltmeter and measure your battery voltage with the disconnect switch in the on and off positions.
When your batteries are charging, the voltage will always increase from when it is not charging.
Here is how to do this:
With disconnect in the off position measure the voltage at the battery.
Unplug your trailer/charger.
If the voltage drops, then your batteries are charging with the disconnect in the off position.
If the voltage stays the same, then your batteries do not charge with the disconnect in the off position.
05-18-2016, 12:47 PM
Originally Posted by larryandamy
Don't speculate...
What speculation?
If the battery is disconnected it cannot and will not charge period [emoji17]
05-18-2016, 02:23 PM
I have a crusader and with my battery cutoff switch off I can use the auto level control for jacks but not run the slides or anything else. Mine will charge the batteries even with it off. Mines a 2014 model. Just saying!
05-18-2016, 02:28 PM
...and the definitive answer is...it all depends, maybe and maybe not!
2015 335DS
05-18-2016, 02:58 PM
Please show me a wiring diagram that makes it possible.
2008 2500hd Duramax
2015 Columbus 320RS
05-18-2016, 06:31 PM
2008 Coachmen Pathfinder
Mine does. Both battery banks will charge and several other circuits are still live with the disconnect activated. And the chassis battery will charge with the chassis disconnect activated. See the attached drawing.
05-18-2016, 08:50 PM
The chassis disconnect is not in question it is a coach battery disconnect issue. The dwg you posted (only sheet 3 of 5 is posted) does show what appears to be an emergency start tie in and inverter power control along with other powered items but I couldn't find coach battery disconnect interface. Maybe I just can't see it or it is on one of the other sheets. And of course you may also be correct.
05-18-2016, 09:20 PM
Battery disconnect
Sorry about the orientation of the pdf, but it can be rotated by pressing Control, shift and + at the same time.
Actually the disconnect is shown, it's near the top of the page on the left side, but not labeled as such. It is marked BJ1 on the diagram.
I only included sheet 3 because it showed the power wiring. Sheet 1 and 2 are an overview of the whole motorhome showing where parts are located and the interconnection harnesses, sheet 4 is the front fuse box wiring, and sheet 5 is the parts list.
The battery isolation manager can be viewed here: precisioncircuitsinc.com/product/battery-isolation-manager-control-relay-225amp-continuous/
