Old 05-17-2016, 03:52 PM   #1
Does battery charge with disconnect flipped?
So, the question came up about the battery disconnect on my Crusader 296bhs.
I'm of the understanding that the batteries will charge even if the disconnect is flipped (e.g. no lights inside the RV can turn on).
Someone was suggesting my batteries wouldn't charged and I disagreed. My rv is in storage, so I can't check.
What do you all think?
2014 Crusader 296BHS
2015 GMC 2500HD Denali
kohai is offline   Reply With Quote
Old 05-17-2016, 03:59 PM   #2
TURBS's Avatar
If disconnect is off they won't charge.
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "5"
2015 nights camped "34"
Old 05-17-2016, 04:04 PM   #3
I should note that my landing gear do work with the disconnect flipped. That's why I'm assuming the power will also charge the unit.
I may be wrong, as this has come up because my trailer was plugged in over the winter but my batteries were flat this spring and the disconnect was flipped. I didn't plug in the trailer so I can't confirm it was plugged in other than take their word for it.
Old 05-17-2016, 04:07 PM   #4
TURBS's Avatar
Landing gear and or slides are hooked directly to the battery thus bypassing the battery disconnect
Old 05-17-2016, 04:10 PM   #5
TURBS's Avatar
There's no possibly way to charge the battery if it's disconnected sorry
2008 2500hd Duramax
2015 Columbus 320RS
Old 05-17-2016, 04:11 PM   #6
Doh. -1 for me. I'm glad I didn't chew them out too bad for the batteries being flat. They did a battery test and said they are ok. These are deep cycle 6v so I hope they are right.
Old 05-17-2016, 04:12 PM   #7
TURBS's Avatar
2008 2500hd Duramax
2015 Columbus 320RS
Old 05-17-2016, 05:19 PM   #8
Depends on your specific unit. On my Georgetown they will not charge with the batteries disconnected, although as others have pointed out, even disconnected there are a number of loads that are still connected. Frankly I may change that when I connect my solar charge controller and there is no real reason for it to work that way. all it takes is moving a lead from the converter to another post on the disconnect.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 05-18-2016, 11:20 AM   #9
OswegoLion's Avatar
Battery Disconnect
[[B] So when is battery turned off?
OswegoLion is offline   Reply With Quote
Old 05-18-2016, 11:39 AM   #10
camaraderie's Avatar
The usual answer is never completely. BUT you can make it so by mounting a battery disconnect device to the negative terminal and making sure nothing is left connected directly to the negative terminal.
Like this:
Note that the RED cable is connected to the negative post in this picture which is generally not correct...guess someone ran out of black cable!
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
battery
