Old 05-09-2014, 10:32 AM   #11
Platokidd's Avatar
Originally Posted by BigJohnD View Post
If it's too annoying, just put it on high fan and let it go.
I guess I should point out I dont use the auto setting. So if that make the difference I wouldn't know.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 05-09-2014, 10:51 AM   #12
mark0224's Avatar
Auto will turn it on and of as it is needed and that may make a difference allowing it to defrost in between.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 05-09-2014, 10:58 AM   #13
Plain Old Member
On ours now, and the last one, if you turn it on (assuming it's really hot inside), it'll run on high fan until it cools down a little, then it'll swap over to low fan for awhile until it reaches the set temp. Some units though, seem like they get confused figuring out which fan speed they want in auto. We had the control box changed out in the Forester due to some similar problems. In our present unit, the control box is crap as well. You'll hear eratic clicking sometimes like it can't decide what to do. That's on the list of problems while it's in the shop now.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 05-09-2014, 01:29 PM   #14
2014 LaCrosse 324RST
ronconp's Avatar
You are right BigJohnD
I checked the thermostat Manuel and it states the same. At 4 degrees difference it runs one speed and at 5 degrees a faster I'm going to try it on a single speed. I agree a second AC would help.
Thanks everyone for the help.
ronconp is offline   Reply With Quote
Old 06-20-2014, 05:17 PM   #15
I set the fan to run high all the time circulating the air. I know at night I can tell when the compressor cycles off and on but with the fan on high all the time it won't change speeds. Works well
gimp425 is offline   Reply With Quote
dometic
