Old 05-08-2014, 04:09 PM   #1
2014 LaCrosse 324RST
ronconp's Avatar
Dometic AC
Another question about our new trailer. When it starts to heat up outside(right now it is 91 and full sun) the AC will turn off and on. Seems to be cycling and the speed changes. It is still cooling, but the off and on thing doesn't seem normal. It will do this every few minutes. Any ideas will help me understand.
ronconp is offline   Reply With Quote
Old 05-08-2014, 04:11 PM   #2
TURBS's Avatar
Most likely defrosting is my guess.
TURBS
Sabre owners united!
Old 05-08-2014, 04:17 PM   #3
ronconp's Avatar
Thanks f1100turbo
If it is defrosting would this mean it is low on freon?
Old 05-08-2014, 04:27 PM   #4
TURBS's Avatar
Not necessarily.
It could be hot and humid enough that the lower coils are frosting up.
Try a little warmer setting .
20 degrees difference between inside to outside is about max.
TURBS
Old 05-08-2014, 04:32 PM   #5
ronconp's Avatar
It is set on 80 and 91 out side. Where we are sitting the sun will be off the trailer in about an hour and it will stop the cycling.
Old 05-08-2014, 04:32 PM   #6
Oakman's Avatar
I believe that is explained in the manual for your thermostat. Mine does that also and has been since we bought our trailer in March 2012.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 05-08-2014, 04:36 PM   #7
ronconp's Avatar
Thanks Oakman
I'll check out the thermostat manual.
Old 05-09-2014, 08:02 AM   #8
Platokidd's Avatar
I never noticed that with my dometic a/c on my Lacrosse.
Just a question, you dont have a vent or window open slightly? I think that can make it frost up a bit.
Wish I had a 2nd a/c in my unit. One unit works hard to keep up on hot days with no shade.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
Old 05-09-2014, 08:19 AM   #9
mark0224's Avatar
If the condenser on the Ac creates a lot of frost it won't work properly this usually happens when there is high humidity. I had this happen on a car once I just shut it off for 10 to 15 minutes so it thawed then turned it back on and it worked fine for the rest of trip.
It's kind of like defrosting your refrigerator when you do it works more efficient.
What you have described sounds like what I had happen but there could be other things.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 05-09-2014, 08:34 AM   #10
Plain Old Member
The on off thing sucks, but is normal. That's just how the new control box / thermostat works. It decides what speed it wants when in auto, depending on the temp. The older ones had a smooth transition between speeds. First time I dealt with the newer ones on our Forester, I thought something was wrong with it, until I went in several other campers with the same set up. If it's too annoying, just put it on high fan and let it go.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 05-09-2014, 10:32 AM   #11
Platokidd's Avatar
I guess I should point out I dont use the auto setting. So if that make the difference I wouldn't know.
Seasonal
Old 05-09-2014, 10:51 AM   #12
mark0224's Avatar
Auto will turn it on and of as it is needed and that may make a difference allowing it to defrost in between.
Old 05-09-2014, 10:58 AM   #13
Plain Old Member
On ours now, and the last one, if you turn it on (assuming it's really hot inside), it'll run on high fan until it cools down a little, then it'll swap over to low fan for awhile until it reaches the set temp. Some units though, seem like they get confused figuring out which fan speed they want in auto. We had the control box changed out in the Forester due to some similar problems. In our present unit, the control box is crap as well. You'll hear eratic clicking sometimes like it can't decide what to do. That's on the list of problems while it's in the shop now.
Old 05-09-2014, 01:29 PM   #14
ronconp's Avatar
You are right BigJohnD
I checked the thermostat Manuel and it states the same. At 4 degrees difference it runs one speed and at 5 degrees a faster I'm going to try it on a single speed. I agree a second AC would help.
Thanks everyone for the help.
Old 06-20-2014, 05:17 PM   #15
I set the fan to run high all the time circulating the air. I know at night I can tell when the compressor cycles off and on but with the fan on high all the time it won't change speeds. Works well
gimp425 is offline   Reply With Quote
dometic
