Old 10-31-2012, 11:46 AM   #11
UPDATE!
For giggles I went to the Dometic recall website and entered my fridge info..
This particular fridge is affected by the recall from Dometic. Would this recall keep the fridge from cooling? I am on the phone on hold right now with Dometic waiting for a rep..
Does anyone know anything about the recall and what is replaced?
Thanks!
John
2011 Primetime LaCrosse 318BHS Touring Ed
Joined the PT family on 10/2010
2006 Chevrolet 2500HD 4x4 T/V
John
foxhead is offline   Reply With Quote
Old 10-31-2012, 12:11 PM   #12
Originally Posted by foxhead View Post
UPDATE!
Thanks!
John
Recall does not affect my problem. Dometic was less than helpful. Basically said I could buy a new cooling unit or a new fridge.. They said I had done all the tests and it points to a bad cooling unit..
It's only money right...?
John
John
Old 10-31-2012, 03:56 PM   #13
VinceU's Avatar
John
Yes the big recall was due to fires and units affected had a sheet metal shield installed. In your case had the boiler and absorber both been hot that reflects low on refridge. With absorrber cooler than boiler, that points to blockage. Heat is not being absorbed due to no or low flow. I saw somewhere with older unit they would be removed and upended to dislodge the debris. If you can reach the coils while its firing on gas maybe tapping with a soft mallet you can free the blockage. Otherwise if it sounds like duck, smells like a duck, and looks like a duck, it probably is a blockage as you suggested in Post 1. For a sub to repair it get a quote to buy and install the cooling unif for less than a new refridge. Believe reefer repair foks can do less than RV repair shops.
Old 10-31-2012, 05:22 PM   #14
http://www.gasrefrigeration.net/why%20they%20fail.htm
Drmstx62 is offline   Reply With Quote
Old 10-31-2012, 05:24 PM   #15
I would suggest that anyone with an rv and has a fridge would check out this website from my previous post.
Old 10-31-2012, 08:46 PM   #16
Phat Phrog Stunt Crew
elind's Avatar
Is their any codes coming up? My Dometic 1350 shut down twice in our LaCrosse caused by some power issues. My dealer had me reset the circuit board by disconnecting the micro plug for 2 minutes. The board is in the back side under a black box where the glass fuze is located. The micro plug of the circuit board plugs into the back wall. This could help if the controler isn't talking to the refer.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 10-31-2012, 09:04 PM   #17
VinceU's Avatar
Originally Posted by Drmstx62 View Post
Some of this info is dated and not quite accurate. Looks like an old article that was "updated" but whatever Dometic says is discounted. Just sayin tis better to listen to the issuer of the warranty and accept Internet blogs as secondary advice.
Old 11-05-2012, 09:41 AM   #18
I tried all that, thank you for the ideas.
To update all,
The cooling failed. I am getting a new cooling unit.
Thanks.
John
John
318bhs
