Old 06-05-2013, 10:54 AM   #1
door frame
first trip cant shut the bath room door. Seems the casing is falling of and nothing with me to fix. Also the battery disconnect should it not be in,on the switch. Never moved mine since I picked it up at the dealers and got to the drycamp site and no 12volt. Had to pull the switch out seems backwards
vacationer is offline   Reply With Quote
Old 06-05-2013, 11:02 AM   #2
You should expect some problems on your first trip or two. I'm sure your dealer will be happy to remedy that for you at no charge. I know it's not fun having to deal with it.
On the switch, I'd say it is what it is. Not sure why you think it's backwards though. In the old days you used to pull the light switch plunger out to turn on your headlights didn't you?
