Old 05-17-2015, 08:44 PM   #11
Canadian Member
itat's Avatar
Thanks, howie70. That's what mine look like. I have a couple drawers where the catch under the drawer needs to be adjusted so it doesn't scrape the bottom of the drawer.
Old 05-17-2015, 09:17 PM   #12
camaraderie's Avatar
Good pix Howie... thks . for that.
Itat...just first extend the drawer as far is it will come out by itelf. Then press down on one plastic piece and up on the other while continuing to pull the drawer out. If that doesn't work...switch up & down choice and keep pulling the drawer outwards.
Going back in...you don't have to press the plastic...just get it properly in the track and push gently.
You'd think FR might see fit to include this tidbit in their instruction manuals. My dealers service dept. guy I spoke to didn't know the up/down trick. Sheesh...how many hours have been wasted on this!!
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 05-18-2015, 09:26 AM   #13
Bowie
Thanks for the picture, it is exactly what I have.
brireey is offline   Reply With Quote
Old 05-18-2015, 09:40 PM   #14
https://flic.kr/p/tbJSyg
This shows plastic release fully after drawer removal...pushing on the curved side...whether it is up or down will release the little stopper tab.
________
Cam
Old 05-23-2015, 05:45 PM   #15
Canadian Member
itat's Avatar
Finally got a chance to pull the drawers today. It's the large drawers under the u-shaped dinette that have the problem. On both, the catch mechanism under the drawer is rubbing against the bottom of the drawer as you pull it out causing a loud squeal. There's no way to adjust the catch mechanism, avens if I pull up on the drawer as I pull them out, they still squeal.
The bottom material is a bit thin and if you put any weight in the drawer it rubs. One of them squeals even without anything in it.
Has anybody else had this problem and found a solution?
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
2012, crusader
