OK, first time at the dump station... The dealer we purchased the TT from told us that after dumping, we should hook the hose up to a connection and it would spray the tank from the inside and clean it out. Well, I dumped the tanks, and realized, the connect to hook up to was in the front of the trailer so I had to back up. After I got to where I thought I should be I opened the connection to find a normal hose fitting thread. The problem is, the dump station only had a wand for washing out. I did the best I could with holding the end of the wand up against that connection, but I think more water got on the inside of the connections than in the tank. So my question is, what/how do you clean your tank after dumping when all you have is a wand? Should I have sprayed in my drainpipe? I thought that seemed a bit unsanitary to let stuff just flow out onto the ground and hopefully make it into the drain.
Learning as I go...
