Old 03-06-2013, 06:40 PM   #21
07 ThunderRoad's Avatar
Originally Posted by 38FLCamper View Post
This looks to be a Sanibel 3600 floorplan - not sure how you would modify this - It is attached to the slide - but maybe cut the side/front and make a ~45 across from the front to side instead of meeting at a 90??
I just said that - DW
2013 Sanibel 3600 5th, 2007Dodge 2500 Cummins Turbo Diesel, 2WD, 4.10gears, Banks equipped, 18" factory rims
07 ThunderRoad is offline   Reply With Quote
Old 03-06-2013, 06:49 PM   #22
This is DW. I agree. This should be done for both corners to follow not only the esthetics of the bed platform but should have been considered for the safety of anyone who has to work in the confined space of these 90 degree corners. This is a minor imperfection however not only considering the possible injury but the way the platform is built is not consistent with the radius corners of the platform lid and mattress. Make sense?
Old 03-06-2013, 06:52 PM   #23
Measure in from each corner 4", cut straight down and use the pcs to fabricate the new 5.66" surface to fill the 45 corner.
Old 03-06-2013, 06:53 PM   #24
rracer5's Avatar
Stub my toe once, @#$%^&*! Stub my toe again, shame on me, @^%$#&!!! But, I can almost guarantee I will have learned how to walk around that bed without stubbing my toe again.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 03-06-2013, 07:00 PM   #25
what would I do to support the leading edge of the platform?
Old 03-06-2013, 07:06 PM   #26
I would use a pc of 3/4" plywood to make a full width, full height support and use the flimsy paneling to cover it. No one is going to see the seam if you cut it with a sharp knife or veneer blade on a table saw.
Old 03-06-2013, 07:14 PM   #27
Old Coot,
DH is interested in your awning support. Will you be making more?
Old 03-06-2013, 07:25 PM   #28
Old Coot,
I purchased enough tubing material in Haines City, FL to make 10 sets and will start fabrication on them either Fri or Sat. We will be back home in Concord, NC tomorrow. Should have all 10 sets completed by 15Mar. Have 3 or 4 sets already spoken for.
Old 03-06-2013, 07:25 PM   #29
Just Love to Camp
TheFordes's Avatar
I am with Turbs. Being a DW that also make the bed I would wear my Phat Phrog Phuzzy Phippers!!!!
Camped 54 Night 2012
XLR Thunderbolt 386*12
"Bertha The LeadSled" is her name
2012 F450
Virginia
TheFordes is offline   Reply With Quote
Old 03-06-2013, 07:29 PM   #30
Oaklevel's Avatar
Just don't do what I usually do (I have hoof in mouth disease most of the time). Last time the DW tripped over the hose...........I told her to pick up her big feet.................. I lived through it...........
Our son swears we are the only two that can put up with each other
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Oaklevel is online now   Reply With Quote
