Old 05-30-2014, 09:45 AM   #11
Thanks for the information. We are going to the camper tomorrow and hopefully that is the problem.
Sent from my SAMSUNG-SGH-I317 using Forest River Forums mobile app
artanner is offline   Reply With Quote
Old 05-30-2014, 09:52 AM   #12
Infractee
I have the same error code, means a loss of communication with control module. Mine is probably toast because my camper was hit by lightning.
Sent from my SAMSUNG-SGH-I337 using Forest River Forums mobile app
RhoZeta is offline   Reply With Quote
Old 05-30-2014, 12:05 PM   #13
rracer5's Avatar
I hate lightening !!! If close enough (static charge), it will also affect the control box for the Schwintek slides. Fortunately for me, just pushing the reset button inside the control box got it working again. Happened 3 times in the 3 years we owned our Lacrosse,
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 05-31-2014, 03:21 PM   #14
Replaced battery no luck at all
Old 05-31-2014, 03:54 PM   #15
What does the data cable look like? Could this be the issue? How easy to replace?
Old 05-31-2014, 03:55 PM   #16
Rvsunman... Where is the CB panel?
Old 06-01-2014, 08:12 AM   #17
CB = Circuit Breaker. Don't know where the panel is in your unit. You need to know where that is for the same reasons you would need to know in your house. The breaker panel has breakers for all of your electrical loads including both 120 vac and the 12vdc loads. Each of your AC units (If you have 2) will have a 120vac breaker in this panel.
As for the data cable, it will look like a phone cord. It is also possible that the cable has disconnected from the circuit board on the roof or behind the wall mounted thermostat. I would check that too. These cables just plug in like a phone cable, real easy to see and reconnect. I would doubt that this cable is broken and needs replaced, more likely disconnected if anything.
2008 F-450 CC DRW
2013 3500 Sanibel
rvsunman is offline   Reply With Quote
Old 06-01-2014, 09:03 AM   #18
Where is the data cable on the roof located and how do I check where the cable is behind the thermostat? When we replaced the LCD thermostat we reconnected the three wires that screwed into the thermostat then
Old 06-01-2014, 09:28 AM   #19
Did your 2nd. AC come factory installed ? or was it added at the dealer ship? Does your thermostat look like the one Turbs posted previously ?
grayfox is online now   Reply With Quote
Old 06-01-2014, 10:00 AM   #20
We have one AC unit that was factory installed. We replaced just the thermostat. The thermostat is the same kind that was on it previously. It is a Dometic three button LCD screen
