Old 05-11-2011, 08:15 PM   #21
I currently have a problem with my fuse block that works the electric jack, Seems it won't work unless I open the fuse holder and hold the fuse tightly into the fuse holder. Only then can I push the retract or extend switch.
267TacerPa is offline   Reply With Quote
Old 05-12-2011, 05:53 AM   #22
My thoughts..
1. - You could take a small flat blade screwdriver and bend the contacts in the fuse holder to make them more snug. Or you could use a pair of needlenose pliers to create the same effect.
2. - Replace the fuse holder. These are available at any auto parts store and are easily crimped into place after removing the old one. Use heat shrink on the connections or get connectors with built in heat shrink.
John
2011 Primetime LaCrosse 318BHS Touring Ed
Joined the PT family on 10/2010
2006 Chevrolet 2500HD 4x4 T/V
John
foxhead is offline   Reply With Quote
Old 05-14-2011, 06:12 AM   #23
Commercial Member
Talking with our people there could be several minor issues at work from low battery, to loose connectors, bad breaker, etc. Please contact our Customer Service department at
Prime Time Manufacturing, Manufacturers of travel trailers and fifth wheels
and we will start to work on helping you figure it out.
PTM
RV Guy is offline   Reply With Quote
318bhs
