Old 10-06-2017, 07:53 PM   #1
gmcdually05's Avatar
Electrical issue
Does anybody know what's wrong with my unit my three slides that runs on the same button does not work and my auto Jack does not work there is no power to it I checked the fuse breaker's wires can't find anything wrong it's only six months old battery is fully charge and it's plugged in I also checked the fuse by the battery seems to be good
gmcdually05 is offline   Reply With Quote
Old 10-06-2017, 10:20 PM   #2
bikendan's Avatar
Is your battery disconnect switch on or off?
Equalizer WDH
Old 10-06-2017, 10:22 PM   #3
Battery is Connected and the Coach is plugged in also.
Old 10-06-2017, 10:49 PM   #4
rsdata's Avatar
there is usually ALSO a battery disconnect switch in the trailer... it may be off...
you can try this...
1. unplug from the power pedestal
2. does anything that is 12 volts work? like interior lights? or the radio?
If nothing works then there is another switch that is OFF...
mine is a sliver knob close to the converter... pulls out and pushes in
this disconnects 12V battery from all non-essential items to help prevent battery from discharging...
hope this helps
Too much of anything is bad, but too much good whiskey is barely enough. Mark Twain
2014 Shamrock 183
Old 10-06-2017, 10:57 PM   #5
you can try this...
hope this helps
I'll try this in the morning thanks. I will also get back with you Tomorrow Let you know if this works.
Old 10-07-2017, 01:40 AM   #6
bikendan's Avatar
Since you didn't list what PrimeTime trailer you have and it's not in your profile, I can only tell you that my 2016 TracerAir 255 has a battery disconnect switch.
It's in the docking station.
Equalizer WDH
Old 10-07-2017, 01:57 AM   #7
Thanks Try That in the morning I have a 2017 Sanibel 3791
Old 10-07-2017, 09:12 AM   #8
You were 100% Right I Found battery disconnect switch was off outside right where you said it was thank you very much.
Old 10-07-2017, 09:14 AM   #9
Also you were 100% right I Found a battery disconnect switch was Off Thanks For that information.
Old 10-07-2017, 12:39 PM   #10
rracer5's Avatar
you can try this...
hope this helps
This is a prime example of personnel (electrical techs) on an assembly line having their own ideas. On my Sanibel, it was wired so that the hydraulic pump that operates the hydraulic levelers & hydraulic slides stays HOT all the time even with the battery switch OFF. On gmdually05's Sanibel, it was apparently wired so that the battery switch kills everything!
Just wish everybody was "on the same page" but then, we all wouldn't have anything to talk about here.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
electric, electrical
