Old 10-14-2012, 09:09 PM   #1
Entrabond Laminated Floor?
I am looking at the new 360BHS but I have heard bad things about this type of floor. I can't seem to find much info on the net. Can anyone tell me more about it? Thanx in advance.
stephens411 is offline   Reply With Quote
Old 11-11-2012, 12:51 PM   #2
markndeb's Avatar
Go to Prime Time's web site click on the construction tab, they give a very good discription of the floor, there are a lot of "bonded" floors out there, but usually on lighter weight trailers and they use only 2" of styrofoam with 1/4" luan top and bottom. Light but not very strong or durable. Prime Time uses thicker plywood with overlaping joints and thicker foam, my floors are very strong and warm.
Happy Shopping!
markndeb is offline   Reply With Quote
Old 11-12-2012, 06:50 AM   #3
Commercial Member
stephens411 - on this model, the floor is made with 2X3 aluminum floor joists with 3" foam. It is laminated top and bottom with 1/4" plywood and then we overlay it with 5/8" Structurewood. This is the same floor we use on our Sanibel fifth wheels. View the Sanibel brochure on line and you will see a construction specific drawing on the floor assembly. Good luck.
PTM
RV Guy is offline   Reply With Quote
