Old 08-13-2011, 03:04 PM   #1
chromeOkie's Avatar
entry steps stuck
Tried to find a thread on this but didn't have all day to sift through the many search results. My manual entry step into my 2012 PT Tracer 230FBS TT was stuck and wouldn't retract until I leveraged it with a 6ft 2x4. We have had some rain but not sure if that would do it. Any suggestions on lubes, etc.?
2011 F150 Ecoboost FX2 Screw 6.5 bed
2012 FR Tracer 230FBS
chromeOkie is offline   Reply With Quote
Old 08-13-2011, 03:14 PM   #2
looks like your entry step has hit something and is out of shape now causing this problem. It happened to me a while ago with my tent trailer. The best way to repair it if it is feasible will be to remove it from the frame and try to reshape it if this is your problem but for me I think this is the problem! Try to lift up the step at the same time that you open it toward you.
capucine is offline   Reply With Quote
Old 08-13-2011, 03:35 PM   #3
Oakman's Avatar
Did you try WD-40??
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 08-17-2011, 12:39 PM   #4
chromeOkie's Avatar
I don't think this is it, just got the TT and have not even done the maiden voyage yet. It's been parked next to the house but we've had somegood rains and steps always extended so that's why I thought rain affected them. Kinda new for this problem I would think. thanks tho
Old 08-17-2011, 12:58 PM   #5
TURBS's Avatar
there are like 6 or 8 hinge points that get rusty and freeze up id spray the heck out of them and keep working it back and forth .
Old 08-17-2011, 10:21 PM   #6
chromeOkie's Avatar
think I'll do that, thanks. but rusting that much that quick?
Old 08-18-2011, 07:47 AM   #7
Mine was very stiff when i brought it home. Sprayed the pivots points with lube and the channels where it slides I greased. Smooth as butter! I am worried that dirt will start building up on the grease, so I'm going to try a dry lube soon.
Len & Cheri is offline   Reply With Quote
Old 08-18-2011, 08:10 AM   #8
Rugged Brown's Avatar
My dealer told me that a little rust is good in this case. If the steps are greased up too much, they may just open when your travelling. Said he had it happen before.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 08-18-2011, 08:19 AM   #9
TURBS's Avatar
Your most certainly right!
I had this happen once on a very windy day . Steps folded out once but not all the way.
Old 08-18-2011, 09:48 AM   #10
chromeOkie's Avatar
I think I prefer the tight step instead of it opening while drving. I'll just keep that 5' board for leverage.
