Old 07-01-2012, 06:28 PM   #1
equalizer adjustments
Got a new TV....broke down and bought an Ecoboost F150. Question, when adjusting, how do you know how many spacer washers you need? Going from a Titan SWB of 140" to F150 with 157" wheelbase. Do you think that I will need to add a washer or two?
Actually, I took measurements as described in the manual. Here are the measeurements from ground to fender well.....
Unloaded
39 3/34 inches rear 37 1/2 inches front
Hooked up without weight distribution
37 1/4 rear 38 1/4 front
with current weight distribution
37 5/8 front 37 5/8 rear exactly the same
looks level without any sagging at all....looks like the setting may work with the change from the Titan to the F150
what do you think???? opinions appreceiated
2011 Lacrosse 318BHS Touring Edition
2012 Ford F150 SupCrew 4x4 XLT 6.5' Max Tow
padave65 is offline   Reply With Quote
Old 07-01-2012, 10:29 PM   #2
Dave_Monica's Avatar
It looks like the W/D is set properly...wouldn't have expected it to change as the hitch weight should have remained the same. I'm more surprised that you didn't have to change the hitch height with the change in TV's. My impression is that the F150's ride height would be higher.
Dave
Old 07-02-2012, 05:56 AM   #3
Actually, I thought the Titan was going to be higher....But it was not. Thanks for your input
equalizer
